| » Spin Cycle Will Not Work |
Model Number: LAT9416AAE Brand: Maytag Age: 1 - 5 years
Spin Will Not Work And You Can Smell The Belt Burning
Will it pump out? Remove the front cover and start a cycle look where the tub and the transmission meet. If water is leaking from there this may cause two problems either the water from the leak is causing the belt to slip or the spin bearing has rusted, locking the tub up. You may just have to replace the belt. Also make sure there isn’t grease from the transmission leaking on the belt causing it to slip. Maytag Washer Repair Guide
| Display Modes | |
| Spin Cycle Does Not Work | MARCUS D. | Washer Repair | 1 | 02-01-2010 10:08 AM |
| Sears - spin cycle does not work | Dano | Washer Repair | 0 | 06-03-2008 04:26 PM |
| Washer spin cycle does not work | valerie | Washer Repair | 5 | 05-20-2008 03:48 PM |
| No spin on regular cycle, others work | klawson | Washer Repair | 2 | 12-05-2007 02:58 PM |
| Spin Cycle will not work | Apache6434 | Washer Repair | 4 | 11-28-2007 03:55 AM |
