teamsideways
#1 Posted : Sunday, October 16, 2011 11:00:28 AM(UTC)
teamsideways
started making odd moaning noises,then got to were it would not spin out,it still fills and drains ok,flashing led on inverter flashes 4 times then pause then 4 times, i checked continuity aross red and yellow wires to mode shifter and have nothing...tried clearing codes,and nothing,resets 4 flashes...mode shifter?..how do i check to make sure i dont have a motor problem also?......this is my mom and dads waher,they are elderly and cant afford a repairman or a new washer,please help
sidfink43
#2 Posted : Tuesday, October 18, 2011 5:42:27 PM(UTC)
sidfink43
Go to this site here. It will tell you how to check it out
HydroWave GE Washer Repair Guide
Good luck, hope it helps
teamsideways
#3 Posted : Wednesday, October 19, 2011 3:52:16 AM(UTC)
teamsideways
thanks....i cleared the code and it comes right back,and it wont even try to aggitate so i guess that means the motor is shot also
GE top load wont spin (Washer Repair)
by NOELLE.EUAN 10/15/2017 5:03:37 PM(UTC)
