| » ted |
Model Number: lw6501w2 Brand: Amana Age: More than 10 years
Got belt for Amanda lw6501w2 and instruction how to remove & install the belt. Difficulty on removing belt from the motor side since, cannot remove the pump.Tryed to shake the plastic pump but the pump doe not come off . Do you need to remove the plastic pump to remove and install the belt? Gave Amanda model # lw2501w2. But should be Amanda model # lw6501w2. Thanks for your help.
ted. Ads By Google Related Models |
You have to remove the motor, then remove the pump. Take out the screws that hold it on. If the pump will not come off it may mean thee is a leak and it has rusted itself onto the motor shaft.
__________________
| Display Modes | |
