amama washer LWA40AW2. installed new belt, new idler pulley. it has 3 cycles: regular, permanet press and delicate. all cycles work except it doesnt agitate on regular and permanent press cycle. it does agitate on delicate wash cycle. water fills, spin works.
the first time we had trouble is before i changed out the old belt, and after i changed the idler pulley.before belt change, i noticed spin cycle was thumping bad, re-arranging clothed helped a bit on balance. next time it was used on regular cycle, it did not stop and went thru all the cycles (on the timer the next is perm. press, then delicate.. its a rotory timer) and it was stopped after we saw it ran thur all three wash cycles, reg., perm. press, and delicate.) timer works, it just doesnt agitate after a fill on reg. and perm. press cycles
any ideas?? thanks in advance! bradp
Since it will operate correctly on one cycle selection, this suggests the timer is the problem.
