Washer shakes the whole house on the spin cycle, what will it take to fix?
Originally Posted by: hunterfarm Washer shakes the whole house on the spin cycle, what will it take to fix? Hunter, A couple of things to check,first: Does the vibration occur with or without a wet load in the drum ? Are all four of the feet/legs, on the floor and locked in place ? Is the washer level in both directions(front to back and side to side) ? Is there vibration or movement in the floor when the washer is in a spin cycle ? :) :) :)
