AppliancePartsPros.com
Appliance Repair Help
Washer Repair
maytag top washer makes noise while spinning only
ok my washer make a lot of noise while spininng but everything works great. i look under the washer and thats where the noise is coming from. on the bottom back right corner face the washer is a small wheel and it seems THAT WHERE THE NOISE COMING FROM or maybe not do you know and what part is it thank you:confused:
Originally Posted by: vpalato ok my washer make a lot of noise while spininng but everything works great. i look under the washer and thats where the noise is coming from. on the bottom back right corner face the washer is a small wheel and it seems THAT WHERE THE NOISE COMING FROM or maybe not do you know and what part is it thank you:confused: Vpalato, The small pulley located on the right rear corner of the base, is the drain pump. Part number: AP4373022
You most likely have a small article(needle , pin, button) in the impeller, causing the noise. You could try and clear the article, or replace the pump. Thanks and Good Luck, :) :) :)
Washer Repair
