Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   maytag top washer makes noise while spinning only (http://forum.appliancepartspros.com/washer-repair/322654-maytag-top-washer-makes-noise-while-spinning-only.html)
vpalato 10-13-2011 10:19 PM
ok my washer make a lot of noise while spininng but everything works great. i look under the washer and thats where the noise is coming from. on the bottom back right corner face the washer is a small wheel and it seems THAT WHERE THE NOISE COMING FROM or maybe not do you know and what part is it thank you:confused:
Joe / APP Team 10-14-2011 10:13 AM
Quote:
Vpalato,
The small pulley located on the right rear corner of the base, is the drain pump.
Part number: AP4373022
You most likely have a small article(needle , pin, button) in the impeller, causing the noise.
You could try and clear the article, or replace the pump.
Thanks and Good Luck,
