tundraspirit
#1 Posted : Friday, May 1, 2009 12:27:43 PM(UTC)
tundraspirit
The old stacked Frigidaire laundry center. This unit is located on our boat. While washing a load of cloths we smelled a burning smell. Stopped the machine and took apart the front cover. Discovered the belt had stopped turning and the pully had almost burnt through the belt.
What should I check? I am able to turn the drum clockwise by hand, however it does not turn counter clockwise. Not sure if this is because it is in spin, or wash cycle ?? The moter seems to be running just fine. :confused:
Frigidaire Laundry Center Dryer Thermocouple replacement (Dryer Repair)
by Guest 8/26/2022 6:04:09 AM(UTC)
Frigidaire Laundry Center FUBAR (Washer Repair)
by tommy1673 1/20/2014 10:32:23 PM(UTC)
Frigidaire laundry center washer motor just hums for 5 seconds and shuts off (Washer Repair)
by rtlind83 3/8/2013 2:07:34 PM(UTC)
Frigidaire laundry center need to replace motor of dryer (Dryer Repair)
by suziguzzi 12/22/2011 4:55:43 AM(UTC)
Frigidaire Laundry Center Dryer Problem (Dryer Repair)
by dee50 6/30/2011 11:25:49 AM(UTC)
Frigidaire Laundry Center (Washer Repair)
by MisterR 6/10/2011 12:37:14 PM(UTC)
frigidaire laundry center washer will not fast spin (Washer Repair)
by keithb505 11/14/2010 7:13:53 AM(UTC)
Frigidaire Laundry Center confused (Washer Repair)
by rodrigo_umana 10/26/2010 6:54:12 PM(UTC)
Frigidaire Laundry Center Electric Dryer (Dryer Repair)
by speedfrk73z 9/22/2010 6:03:14 AM(UTC)
Frigidaire Laundry Center Fault Code E5 (Dryer Repair)
by blakeneys 1/25/2010 8:27:52 AM(UTC)
Frigidaire Laundry Center Slow Spin (Washer Repair)
by txtechnot 9/21/2009 1:55:18 PM(UTC)
Agitator for Frigidaire Laundry Center (Washer Repair)
by Gbear 12/11/2008 3:57:50 PM(UTC)
