Discuss
Mah8700aww
 in
Washer Repair
Water not draining, making a rattle noise as it tries. Figured its the Pump. Took Pump out and apart. Cleaned
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Mah8700aww
  #1 (permalink)
Old 10-12-2011, 05:05 AM
Junior Member
RobertSchwartz is on a distinguished road
Default Mah8700aww
Brand: Maytag   Age: 1 - 5 years
Water not draining, making a rattle noise as it tries. Figured its the Pump. Took Pump out and apart. Cleaned it. Lots of dirt. Still spins really well. Put back in worked fine for a minute. What can go wrong with a pump that spins well? Clog? If clogged where to look on this model. KIDS NEED CLOTHES!!!
Thanks, RS
Ads By Google
  #2 (permalink)
Old 10-13-2011, 06:49 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I am thinking there is still junk in the drain line to the pump. After you cleaned it out the junk drained into the pump again.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
I need the Repair Manual for Maytag Neptune MAH8700AWW AngelCa588 Washer Repair 5 12-16-2012 11:56 PM
Maytag MAH8700AWW water keeps running all the time rd09 Washer Repair 3 02-11-2012 01:59 PM
Maytag MAH8700AWW Undefined Error Code miamichrismeltdown Washer Repair 2 05-22-2010 10:41 PM
Maytag Neptune Mah8700aww Spin Walking wahlflower Washer Repair 1 01-01-2010 02:45 PM
Maytag MAH8700AWW water keeps running rd09 Dishwasher Repair 0 09-01-2009 02:01 PM
