Discuss
Kenmore Series 90 Washer - spin problems
 in
Washer Repair
Washer fills/drains fine. Agitation (wash) cycle works fine. Spin cycle made a loud clicking noise (like a bad bearing) and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Series 90 Washer - spin problems
  #1 (permalink)
Old 10-11-2011, 05:10 PM
Junior Member
dgb20 is on a distinguished road
Default Kenmore Series 90 Washer - spin problems
Model Number: 11022922100   Brand: Kenmore   Age: 5 - 10 years
Washer fills/drains fine. Agitation (wash) cycle works fine. Spin cycle made a loud clicking noise (like a bad bearing) and the drum did not spin. Have a replaced the direct drive couplers/rubber grommet (the old ones looked fine) and the clutch assembly. Now the drum moves in a "jerky" motion during spin, like something is slipping.
What is the most likely culprit? Transmission? Brakes? ??
Related Models
Kenmore 11022922100 WASHER
Kenmore 11022922101 AUTOMATIC WASHER
Kenmore 11022922102 AUTOMATIC WASHER
Kenmore 11022924100 WASHER
Kenmore 11022924101 AUTOMATIC WASHER
Kenmore 11022924102 AUTOMATIC WASHER
Kenmore 11022932100 WASHER
Kenmore 11022932101 AUTOMATIC WASHER
Kenmore 11022932102 AUTOMATIC WASHER
Kenmore 11022936100 WASHER
Kenmore 11022936101 AUTOMATIC WASHER
Kenmore 11022936102 AUTOMATIC WASHER
Kenmore 11022942100 WASHER
Kenmore 11022942101 AUTOMATIC WASHER
Kenmore 11022942102 AUTOMATIC WASHER
Kenmore 11022952100 WASHER
Kenmore 11022952101 AUTOMATIC WASHER
Kenmore 11022952102 AUTOMATIC WASHER
Kenmore 11022954100 WASHER
Kenmore 11022954101 AUTOMATIC WASHER
Kenmore 11022954102 AUTOMATIC WASHER
Kenmore 11022956100 WASHER
Kenmore 11022956101 RESIDENTIAL WASHER
Kenmore 11022956102 AUTOMATIC WASHER
Kenmore 11022972100 WASHER
Kenmore 11022972101 WASHER
Kenmore 11022972102 WASHER
Kenmore 11022972103 AUTOMATIC WASHER
Kenmore 11022974100 WASHER
Kenmore 11022974101 WASHER
Kenmore 11022974102 WASHER
Kenmore 11022974103 AUTOMATIC WASHER
Kenmore 11022982100 WASHER
Kenmore 11022982101 WASHER
Kenmore 11022982102 WASHER
Kenmore 11022982103 AUTOMATIC WASHER
Kenmore 11022992100 WASHER
Kenmore 11022992101 WASHER
Kenmore 11022992102 AUTOMATIC WASHER
Kenmore 11022992103 AUTOMATIC WASHER
Kenmore 11022994100 WASHER
Kenmore 11022994101 WASHER
Kenmore 11022994102 AUTOMATIC WASHER
Kenmore 11022994103 AUTOMATIC WASHER
Kenmore 11022996100 WASHER
Kenmore 11022996101 WASHER
Kenmore 11022996102 AUTOMATIC WASHER
Kenmore 11022996103 AUTOMATIC WASHER
Kenmore 11023012100 AUTOMATIC WASHER
Kenmore 11023012101 AUTOMATIC WASHER
Kenmore 11023012102 AUTOMATIC WASHER
Kenmore 11023014100 AUTOMATIC WASHER
Kenmore 11023014101 AUTOMATIC WASHER
Kenmore 11023014102 AUTOMATIC WASHER
Kenmore 11023022100 AUTOMATIC WASHER
Kenmore 11023022101 AUTOMATIC WASHER
Kenmore 11023022102 AUTOMATIC WASHER
Kenmore 11023024100 AUTOMATIC WASHER
Kenmore 11023024101 AUTOMATIC WASHER
Kenmore 11023024102 AUTOMATIC WASHER
Kenmore 11023032100 WASHER
Kenmore 11023032101 AUTOMATIC WASHER
Kenmore 11023032102 AUTOMATIC WASHER
Kenmore 11023034100 WASHER
Kenmore 11023034101 AUTOMATIC WASHER
Kenmore 11023034102 AUTOMATIC WASHER
Kenmore 11023036100 WASHER
Kenmore 11023036101 AUTOMATIC WASHER
Kenmore 11023036102 AUTOMATIC WASHER
Kenmore 11023652200 AUTOMATIC WASHER
Kenmore 11023662200 AUTOMATIC WASHER
Kenmore 11023692200 AUTOMATIC WASHER
Kenmore 11023712200 AUTOMATIC WASHER
Kenmore 11023722200 AUTOMATIC WASHER
Kenmore 11023732200 AUTOMATIC WASHER
Kenmore 11023812100 AUTOMATIC WASHER
Kenmore 11023822100 AUTOMATIC WASHER
Kenmore 11023832100 AUTOMATIC WASHER
Kenmore 11023902200 AUTOMATIC WASHER
Kenmore 11023902201 AUTOMATIC WASHER
Kenmore 11023904200 AUTOMATIC WASHER
Kenmore 11023904201 AUTOMATIC WASHER
Kenmore 11023912100 AUTOMATIC WASHER
Kenmore 11023912101 AUTOMATIC WASHER
Kenmore 11023912102 AUTOMATIC WASHER
Kenmore 11023922200 AUTOMATIC WASHER
Kenmore 11023922201 AUTOMATIC WASHER
Kenmore 11023924200 AUTOMATIC WASHER
Kenmore 11023924201 AUTOMATIC WASHER
Kenmore 11023932200 WASHER
Kenmore 11023934200 WASHER
Kenmore 11024032301 AUTOMATIC WASHER
Kenmore 11024036301 AUTOMATIC WASHER
Kenmore 11024042301 AUTOMATIC WASHER
Kenmore 11024052300 AUTOMATIC WASHER
Kenmore 11024054300 AUTOMATIC WASHER
Kenmore 11024056300 AUTOMATIC WASHER
Kenmore 11024082200 AUTOMATIC WASHER
Kenmore 11024084200 AUTOMATIC WASHER
Kenmore 11024086200 AUTOMATIC WASHER
Kenmore 11024292300 AUTOMATIC WASHER
Kenmore 11024294300 AUTOMATIC WASHER
Kenmore 11024422300 AUTOMATIC WASHER
Kenmore 11024432300 AUTOMATIC WASHER
Kenmore 11024442300 AUTOMATIC WASHER
Kenmore 11024622300 AUTOMATIC WASHER
Kenmore 11024632300 AUTOMATIC WASHER
Kenmore 11024642300 AUTOMATIC WASHER
Kenmore 11024652300 AUTOMATIC WASHER
Kenmore 11024662300 AUTOMATIC WASHER
Kenmore 11024692300 AUTOMATIC WASHER
Kenmore 11024712300 AUTOMATIC WASHER
Kenmore 11024722300 AUTOMATIC WASHER
Kenmore 11024732300 AUTOMATIC WASHER
Kenmore 11024812200 AUTOMATIC WASHER
Kenmore 11024812201 AUTOMATIC WASHER
Kenmore 11024822200 AUTOMATIC WASHER
Kenmore 11024822201 AUTOMATIC WASHER
Kenmore 11024832200 AUTOMATIC WASHER
Kenmore 11024832201 AUTOMATIC WASHER
  #2 (permalink)
Old 10-13-2011, 06:43 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Based on your info and what you have done I think the problem is in the brakes. See the Sticky at the top of this page on direct drive brakes by Richappy for more info.
__________________
  #3 (permalink)
Old 10-19-2011, 03:52 PM
Junior Member
Default
Quote:
Checked the brakes. I can turn them easily (counter clockwise). I cleaned, lightly sanded, and sprayed a light coat of WD40 on the brake drum while turning the brakes. While I had it apart, I visually checked (again) the basket drive block and brake & drive tube to ensure the tabs were lined up and not worn. This is the video of the machine upon reassembly Kenmore Washer Series 90 Spin Problem... - YouTube
The jerking motion is still there on the spin cycle. Any additional ideas? Transmission? If so, is there a way to check it without opening the cover?
  #4 (permalink)
Old 10-19-2011, 05:38 PM
Senior Expert
APP Volunteer
Default
I don't think it is the transmission. Try changing out the springs and the clutch lining. It is just hard for us to diagnose something like this without being there to see it.
__________________
  #5 (permalink)
Old 10-19-2011, 08:52 PM
Junior Member
Default
I actually replaced the entire clutch assembly (kit with a new housing, lining, brake cam driver, etc) Part Number: AP3094537. I checked to ensure it was installed correctly and had the spring facing the motor (the spring on the brake assembly was at the top) when I reassembled. I suppose it is possible that the new one is bad. I made sure that I used the same color spring as the old one.
Thoughts? I know it is tough to troubleshoot when you cannot see everything - but thanks for trying.
  #6 (permalink)
Old 10-20-2011, 04:19 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Probably a bad tranny, remove the pump and motor and turn the tranny coupler clockwise till spin engages. Continue turning, if you feal a rough spot, you have a busted nylon gear in the tranny.
__________________
  #7 (permalink)
Old 10-20-2011, 01:42 PM
Junior Member
Default
Quote:
Thanks for the info Richappy - ok, was able to turn a few rotations (clockwise) and started feeling a roughness in the motion, like a cog not quite messing properly. I as I continued to turn, the clutch housing made a slight movement (clockwise) and I cannot turn the coupler any more (clockwise). I am assuming the rough motion I felt is what you described - so most likely a new transmission is in order?
Update 11/5/11: New transmission arrived and once installed everything working fine. Thanks everyone
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore washer series 90 spin problem Toby1 Washer Repair 7 08-10-2011 04:49 AM
Kenmore washer 80 series won't agitate or spin Michelesbratz@aol.com Heating, Ventilation, and Air Conditioning (HVAC) 0 09-27-2010 09:41 AM
Kenmore 80 Series Washer Won't Spin lbunay Dishwasher Repair 3 09-16-2010 07:31 AM
Kenmore Series 80 washer won't spin cwenzel Dishwasher Repair 0 09-05-2010 03:13 PM
Kenmore Series 70 Washer will not Spin syeager Washer Repair 1 06-02-2009 06:02 PM
