Discuss
Washer Leaks
 in
Washer Repair
When I set the water level to "ex high" and wash a load of clothes washer leaks. Does not leak
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Leaks
  #1 (permalink)
Old 04-30-2009, 08:50 PM
Junior Member
varsboyd is on a distinguished road
Default Washer Leaks
Model Number: 70 Series   Brand: Kenmore   Age: More than 10 years
When I set the water level to "ex high" and wash a load of clothes washer leaks. Does not leak when water level is set to "ex low" or "med". Do you think that it is the Tub Ring Seal?
Related Models
Amana 70/05.00 COMMERCIAL MICROWAVES
Amana 70/05.01 COMMERCIAL MICROWAVES
Amana 70/05.02 COMMERCIAL MICROWAVES
Amana 70/05.030 COMMERCIAL MICROWAVES
Amana 70/05.52SS COMMERCIAL MICROWAVES
Amana 70/05.530SS COMMERCIAL MICROWAVES
Amana 70/05.540SS COMMERCIAL MICROWAVES
Amana 70/05.550SS COMMERCIAL MICROWAVES
Amana 70/05.72 COMMERCIAL MICROWAVES
Amana 70/05.730 COMMERCIAL MICROWAVES
Amana 70/05.740 COMMERCIAL MICROWAVES
Amana 70/08.00 COMMERCIAL MICROWAVES
Amana 70/08.001 COMMERCIAL MICROWAVES
Amana 70/08.002 COMMERCIAL MICROWAVES
Amana 70/08.502 COMMERCIAL MICROWAVES
Amana 70/09.100 COMMERCIAL MICROWAVES
Amana 70/09.102 COMMERCIAL MICROWAVES
Amana 70/09.301 COMMERCIAL MICROWAVES
Amana 70/10.00 COMMERCIAL MICROWAVES
Amana 70/10.01 COMMERCIAL MICROWAVES
Amana 70/10.03 COMMERCIAL MICROWAVES
Amana 70/10.08 COMMERCIAL MICROWAVES
Amana 70/10.09 COMMERCIAL MICROWAVES
Amana 70/10.11 COMMERCIAL MICROWAVES
Amana 70/15.00 COMMERCIAL MICROWAVES
Amana 70/15.01 COMMERCIAL MICROWAVES
Amana 70/15.02 COMMERCIAL MICROWAVES
Amana 70/15.03 COMMERCIAL MICROWAVES
Amana 70/20.00 COMMERCIAL MICROWAVES
Amana 70/20.01 COMMERCIAL MICROWAVES
Amana 70/20.03 COMMERCIAL MICROWAVES
Amana 70/20.04 COMMERCIAL MICROWAVES
Amana 70/20.05 COMMERCIAL MICROWAVES
Amana 70/20.06 COMMERCIAL MICROWAVES
Amana 70/20.07 COMMERCIAL MICROWAVES
Amana 70/20.08 COMMERCIAL MICROWAVES
Amana 70/20.09 COMMERCIAL MICROWAVES
Amana 70/20.10 COMMERCIAL MICROWAVES
Amana 70/20.11 COMMERCIAL MICROWAVES
Amana 70/30.00 COMMERCIAL MICROWAVES
Amana 70/30.01 COMMERCIAL MICROWAVES
Amana 70/30.02 COMMERCIAL MICROWAVES
Amana 70/30.03 COMMERCIAL MICROWAVES
Amana 70/30.05 COMMERCIAL MICROWAVES
Amana 70/30.06 COMMERCIAL MICROWAVES
Amana 70/30.07 COMMERCIAL MICROWAVES
Amana 70/30.08 COMMERCIAL MICROWAVES
Amana 70/30.09 COMMERCIAL MICROWAVES
Amana 70/30.10 COMMERCIAL MICROWAVES
Amana 70/30.11 COMMERCIAL MICROWAVES
Amana 70/40 COMMERCIAL MICROWAVES
Amana 70/40.01 COMMERCIAL MICROWAVES
Amana 70/40.02 COMMERCIAL MICROWAVES
Amana 70/40.03 COMMERCIAL MICROWAVES
Amana 70/40.05 COMMERCIAL MICROWAVES
Amana 70/40.06 COMMERCIAL MICROWAVES
Amana 70/40.07 COMMERCIAL MICROWAVES
Amana 70/40.08 COMMERCIAL MICROWAVES
Amana 70/40.09 COMMERCIAL MICROWAVES
Amana 70/40.10 COMMERCIAL MICROWAVES
Amana 70/40.11 COMMERCIAL MICROWAVES
Amana 70/42 COMMERCIAL MICROWAVES
Amana 70/42.01 COMMERCIAL MICROWAVES
Amana 70/45.100 COMMERCIAL MICROWAVES
Amana 70/45.101 COMMERCIAL MICROWAVES
Amana 70/45.102 COMMERCIAL MICROWAVES
Amana 70/45.300 COMMERCIAL MICROWAVES
Amana 70/45.301 COMMERCIAL MICROWAVES
Amana 70/45.302 COMMERCIAL MICROWAVES
Amana 70/50.00 COMMERCIAL MICROWAVES
Amana 70/50.01 COMMERCIAL MICROWAVES
Amana 70/50.02 COMMERCIAL MICROWAVES
Amana 70/50.03 COMMERCIAL MICROWAVES
Amana 70/50.05 COMMERCIAL MICROWAVES
Amana 70/50.06 COMMERCIAL MICROWAVES
Amana 70/50.07 COMMERCIAL MICROWAVES
Amana 70/50.08 COMMERCIAL MICROWAVES
Amana 70/50.09 COMMERCIAL MICROWAVES
Amana 70/50.10 COMMERCIAL MICROWAVES
Amana 70/50.11 COMMERCIAL MICROWAVES
Amana 70/50.12 COMMERCIAL MICROWAVES
Amana 70/52.00 COMMERCIAL MICROWAVES
Amana 70/52.01 COMMERCIAL MICROWAVES
Amana 70/55.100B COMMERCIAL MICROWAVES
Amana 70/55.100D COMMERCIAL MICROWAVES
Amana 70/55.100VP COMMERCIAL MICROWAVES
Amana 70/55.300B COMMERCIAL MICROWAVES
Amana 70/55.300D COMMERCIAL MICROWAVES
Amana 70/55.300VP COMMERCIAL MICROWAVES
Amana 70/80.00 COMMERCIAL MICROWAVES
Amana 70/80.005 COMMERCIAL MICROWAVES
Amana 70/80.006 COMMERCIAL MICROWAVES
Amana 70/80.007 RANGE- S/C S/I DDRAFT GAS
Amana 70/80.01 COMMERCIAL MICROWAVES
Amana 70/80.02 COMMERCIAL MICROWAVES
Amana 70/80.03 COMMERCIAL MICROWAVES
Amana 70/80.04 COMMERCIAL MICROWAVES
Amana 70/80.MEX COMMERCIAL MICROWAVES
Amana 7000.000 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 7001-80A ELECTRIC DRYER
Frigidaire 7007-80C ELECTRIC DRYER
Frigidaire 7007-80D ELECTRIC DRYER
Frigidaire 7007-80E ELECTRIC DRYER
Frigidaire 7007-87C ELECTRIC DRYER
Frigidaire 7007-87D ELECTRIC DRYER
Frigidaire 7007-87E ELECTRIC DRYER
Frigidaire 7007B ELECTRIC DRYER
Hoover 701
Hardwick 70131 RANGE- F/S STD GAS
Hardwick 70138 RANGE- F/S STD GAS
Maytag 701C DRYER- GAS
Hardwick 70231 RANGE- F/S STD GAS
Hardwick 70238 RANGE- F/S STD GAS
Hoover 704
Hoover 704-01
Hoover 705
Hoover 706
Hoover 707
Amana 7096 MWAVE - FAMILY SIZE (60 HZ)
Maytag 70C DRYER- GAS
  #2 (permalink)
Old 05-01-2009, 03:40 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Need model # to help.
__________________
  #3 (permalink)
Old 05-01-2009, 09:04 AM
Junior Member
Default
Sorry about that. The model number is: 110.82372120.
  #4 (permalink)
Old 05-01-2009, 09:42 AM
Senior Expert
APP Volunteer
Default
You have the old type washer. Yank the top up and look at the bottom of the tub, if you see water coming out, you probably have a bad tub seal or a rusted out tub. Probably not worth fixing, will have to remove the tub to put new seal in and you may find rust holes in the steel tub.
__________________
  #5 (permalink)
Old 05-01-2009, 02:42 PM
Junior Member
Default
Thanks. Since water only leaks out when I set the water level to "ex high" and wash a load of clothes wouldn't that lead you to believe that the tub ring seal that fits on top of the basket and tub is leaking as oppose to the tub being rusted out? Thanks for your time.
  #6 (permalink)
Old 05-01-2009, 04:17 PM
Senior Expert
APP Volunteer
Default
Small tub leaks will get bigger and more noticeable due to the increased water pressure. Sometimes, if the snubber is worn, and it shakes in spin, it could splash out over the rim of the tub.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer leaks bigfritschy Washer Repair 1 10-15-2009 01:31 PM
washer leaks fix178 Washer Repair 0 08-25-2009 11:48 AM
washer leaks dr.bob Washer Repair 2 02-24-2009 06:57 PM
washer leaks allen9258 Washer Repair 1 12-18-2008 08:33 PM
