Soundtime
#1 Posted : Thursday, April 30, 2009 2:14:46 PM(UTC)
Soundtime
When washing clothes the cycle will stop in the middle. I found out that the lid presses through the metal to a plastic assembly that triggers the washer to spin. Well, that piece broke. So I ordered a new assembly. My question is how do I install it. Looks like I have to take off the top part of the washer. How do you do that?? Thanks.
Drags1998
#2 Posted : Thursday, April 30, 2009 2:46:38 PM(UTC)
Drags1998
The top DOES NOT come off!!!!! find the 2 screws that hold the console in place, remove them, slide the console foward 1/2" and rotate it over backwards. Remove the Gold colored clips by inserting a flat screwdriver and PRYING backwards. Unplug the 3 wire lid switch connecter, pull the ENTIRE cabinet off by lifting the rear up and then sliding it forward.:)
Soundtime
#3 Posted : Thursday, April 30, 2009 3:16:40 PM(UTC)
Soundtime
When you say console, what exactly are you referring too? If you can describe the whole process again, so I can understand it. Thanks.
Drags1998
#4 Posted : Thursday, April 30, 2009 3:46:24 PM(UTC)
Drags1998
The CONSOLE is the panel that contains all of the controls, My description is VERY CLEAR, Please read it again!!!
Soundtime
#5 Posted : Tuesday, May 5, 2009 10:28:42 AM(UTC)
Soundtime
I have the new piece hooked up..The problem I am having is how to put the two gold pieces back in place. Please help. Thanks.
Drags1998
#6 Posted : Tuesday, May 5, 2009 12:49:51 PM(UTC)
Drags1998
Get the cabinet sitting back onto the base frame, open the lid and hook the lip on the bottom of the cabinet, under the frame at the front of the washer. then allow the cabinet to fall back to level, There are 2 tabs on the rear SIDES of the frame, These slide into 2 slots in the cabinet bottom, once you have the cabinet in place, Hold the clips in your hand, with the 1/2 loop between your thumb and finger, The SMALL 90degree end goes into the SLOT in the REAR panel with the end facing up(that lines up with the SQUARE HOLES) Then the 1/2 loop "POPS" down into the top of the washer!!!!!:)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool washer F20 code (Washer Repair)
by wstrick14 1/6/2024 3:42:34 PM(UTC)
Whirlpool washer clicking when filling (Washer Repair)
by RogeM 12/3/2023 8:13:49 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
whirlpool washer buzzer Way too loud! (Washer Repair)
by Guest 5/1/2023 11:33:43 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Whirlpool washer spins during drain cycle (Washer Repair)
by jsdscot 1/23/2023 5:04:07 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
whirlpool washer fill and drain only (Washer Repair)
by Randero 10/14/2022 2:53:13 AM(UTC)
Capacitor for Front Load Whirlpool washer Model # wfw9550ww00 (Washer Repair)
by Guest 9/11/2022 2:49:05 PM(UTC)
Whirlpool Washer does everything, but RINSE - even after new parts (Washer Repair)
by nryuhasz@hotmail.com 5/26/2022 7:09:28 AM(UTC)
Whirlpool Washer Stuck in Drain Mode (Washer Repair)
by Greg72 2/15/2022 1:07:03 PM(UTC)
