Discuss
leak on ge washer
 in
Washer Repair
appears to have a leak at the base of the tub, where the drive shaft goes in the middle, just
Appliance Repair Forum > Appliance Repair Help > Washer Repair » leak on ge washer
  #1 (permalink)
Old 12-06-2007, 08:56 PM
shopower shopower is offline
Junior Member
shopower is on a distinguished road
Default leak on ge washer
Model Number: whdsr315d   Brand: GE   Age: 1 - 5 years
appears to have a leak at the base of the tub, where the drive shaft goes in the middle, just a seal? any tips on removal/inspection? maybe even a part number I can use, this site doesn't list my model in their database. maybe something crosses over from another model?
thanks in advance
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-08-2007, 09:44 PM
Junior Member
Default
well I got the seal, now I have to figure out how to get the tub out, I have the top of the washer off, and I took the agitator off, I removed all the fasteners I could see on the drive shaft, but the tub won't come out, it looks rusty, I wonder if that's all that's holding it on or is there a snap ring or something that I can't see? any ideas????
  #3 (permalink)
Old 12-09-2007, 03:30 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You have an aluminum left hand nut holding the tub in place that likes to rust solid to the tub.I have one on a GE washer that I never got off!!
First, you will need the special spanner wrench and a lot of pounding to get it off.
Please Please inform us if you got it off and explain HOW.
I tried penetrating oil and a cold chisel with no success. I think you have a plastic tub, so a blowtorch is a bad idea.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore washer oil leak bobtx Washer Repair 3 05-11-2008 07:56 AM
leak? Rayh Washer Repair 2 11-14-2007 08:58 AM
leak? Rayh Washer Repair 3 11-14-2007 08:31 AM
Hotpoint Washer Leak dperry Washer Repair 0 11-12-2007 09:53 PM
oil leak from under ge profile washer husker Washer Repair 0 10-14-2007 01:21 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
