Discuss
Maytag Stackable 2000 won't spin!
 in
Washer Repair
Here's another Maytag that has trouble with the spin cycle however, the Machine control board has been changed and the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Stackable 2000 won't spin!
  #1 (permalink)
Old 04-29-2009, 09:19 PM
Junior Member
Marcus1260 is on a distinguished road
Red face Maytag Stackable 2000 won't spin!
Model Number: MLG2000AWW   Brand: Maytag   Age: 5 - 10 years
Here's another Maytag that has trouble with the spin cycle however, the Machine control board has been changed and the R-11 was not burnt out in the old board.
The door lock light is on during the spin cycle and the water pumps out and the drum seems to be tumbling slowly. Someone mentioned that I have to replace the Motor Control board and that possibly, the motor will have to be replaced, too.
Found the part number 12002039 that has a diagram that show the parts as it is in the machine but when I pull up a picture of the control board, it looks very different. It also mentions that there are different Series for the same part number and from what I understand, that the first two numbers of the Serial Number would be the Series number. I that true? (Series# 24593828YM, so Series 24) Then use the part with the series number that is below my series number!!! Right??? Whew!
Well, any help you can give would be most appreciated.
Thanks so much!
Ads By Google
Related Models
Maytag MLG2000AWW Stacked Laundry - Gas
Maytag MLG2000AXW Stacked Laundry - Gas
Maytag MLG23MNAWW Stacked Dryer - Gas
Maytag MLG23MNFWW Stacked Dryer - Gas
International MLG23PDAGW Dryer - Gas
Maytag MLG23PDAWQ Dryer - Gas
Maytag MLG23PDAWW Dryer - Gas
Maytag MLG23PDAYQ Dryer - Gas
Maytag MLG23PDFGW Stacked Dryer - Gas
Maytag MLG23PDFWW Stacked Dryer - Gas
Maytag MLG23PDFXW Stacked Dryer - Gas
Maytag MLG23PDHGW Stacked Dryer - Electric
Maytag MLG23PDHWW Stacked Dryer - Electric
Maytag MLG23PDHXW Stacked Dryer - Electric
Maytag MLG23PRAWW Dryer - Gas
Maytag MLG23PRFWW Stacked Dryer - Gas
Maytag MLG23PRFXW Stacked Dryer - Gas
Maytag MLG31PCAWQ Dryer - Gas
Maytag MLG31PCAWS Dryer - Gas
Maytag MLG31PCAWW Dryer - Gas
Maytag MLG31PCBWQ Stacked Dryer - Gas
Maytag MLG31PCBWS Stacked Dryer - Gas
Maytag MLG31PCBWW Stacked Dryer - Gas
Maytag MLG32PDAWA Stacked Dryer - Gas
Maytag MLG32PDAWW Stacked Dryer - Gas
Maytag MLG32PDBWA Stacked Dryer - Gas
Maytag MLG32PDBWQ Stacked Dryer - Gas
Maytag MLG32PDBWS Dryer - Gas
Maytag MLG32PDBWW Stacked Dryer - Gas
Maytag MLG33PDAWS Dryer - Gas
Maytag MLG33PDAWW Dryer - Gas
Maytag MLG33PDSWS Dryer - Gas
Maytag MLG33PDSWW Dryer - Gas
Maytag MLI7000AAW Small Appliances
Maytag MLI7500AAW Small Appliances
Amana MLMTK1 Misc / Accessory
International MLR1100AJQ Range - F/s Std Gas
International MLR1100AJW Range - F/s Std Gas
International MLR1110AJQ Range - F/s Std Gas
International MLR1110AJW Range - F/s Std Gas
International MLR1415AJQ Range - F/s Std Gas
International MLR1415AJS Range - F/s Std Gas
International MLR1415AJW Range - F/s Std Gas
International MLR4410BXH Range - F/s Std Gas
International MLR4410BXL Range - F/s Std Gas
International MLR4410BXT Range - F/s Std Gas
International MLR4410CXH Range - F/s Std Gas
International MLR4410CXT Range - F/s Std Gas
International MLR4451AJQ Range - F/s Std Gas
International MLR4451AJS Range - F/s Std Gas
International MLR4451AJW Range - F/s Std Gas
International MLR5755QDQ Range - S/c F/s Gas
International MLR5755QDS Range - S/c F/s Gas
International MLR5755QDW Range - S/c F/s Gas
Frigidaire MLSE62RFD0 Frg(v1) / Laundry Center
Frigidaire MLSE62RFD1 Frg(v1) / Laundry Center
Frigidaire MLSE62RFW0 Frg(v2) / Laundry Center
Frigidaire MLSE62RFW1 Frg(v2) / Laundry Center
Frigidaire MLSE62RFW2 Frg(v0) / Laundry Center
Frigidaire MLSG62RFD0 Frg(v1) / Laundry Center
Frigidaire MLSG62RFD1 Frg(v1) / Laundry Center
Frigidaire MLSG62RFW0 Frg(v2) / Laundry Center
Frigidaire MLSG62RFW1 Frg(v2) / Laundry Center
Frigidaire MLXE42RBD0 Frg(v2) / 27 " Laundry Center
Frigidaire MLXE42RBD1 Frg(v1) / 27 " Laundry Center
Frigidaire MLXE42RBD2 Frg(v1) / Laundry Center
Frigidaire MLXE42RBD3 Frg(v1) / Laundry Center
Frigidaire MLXE42RBW0 Tap(v4) / 27 " Laundry Center
Frigidaire MLXE42RBW1 Frg(v2) / 27 " Laundry Center
Frigidaire MLXE42RBW2 Frg(v2) / Laundry Center
Frigidaire MLXE42RBW3 Frg(v2) / Laundry Center
Frigidaire MLXE42RBWD0 Kel(v10) / 27 " Laundry Center
Frigidaire MLXE42RBWL0 Frg(v2) / 27 " Laundry Center
Frigidaire MLXE42RBWW0 Frg(v1) / 27 " Laundry Center
Frigidaire MLXE42RED0 Frg(v1) / Laundry Center
Frigidaire MLXE42RED3 Frg(v1) / Laundry Center
Frigidaire MLXE42RED4 Frg(v1) / Laundry Center
Frigidaire MLXE42RED5 Frg(v1) / Laundry Center
Frigidaire MLXE42REW0 Frg(v2) / Laundry Center
Frigidaire MLXE42REW1 Frg(v0) / Laundry Center
Frigidaire MLXE42REW2 Frg(v0) / Laundry Center
Frigidaire MLXE42REW3 Frg(v2) / Laundry Center
Frigidaire MLXE42REW4 Frg(v2) / Laundry Center
Frigidaire MLXE42REW5 Frg(v2) / Laundry Center
Uni MLXE42REW6 Laundry Center - Universal
Uni MLXE42REW7 Universal/laundry Center
Uni MLXE42REW8 Universal/laundry Center
Uni MLXE42RFW0 Universal/laundry Center
Frigidaire MLXE62RBD0 Frg(v2) / 27 " Electric Laundry Center
Frigidaire MLXE62RBD1 Frg(v1) / 27 " Electric Laundry Center
Frigidaire MLXE62RBD2 Frg(v1) / Laundry Center
Frigidaire MLXE62RBD3 Frg(v1) / Laundry Center
Frigidaire MLXE62RBW0 Tap(v4) / 27 " Electric Laundry Center
Frigidaire MLXE62RBW1 Frg(v2) / 27 " Electric Laundry Center
Frigidaire MLXE62RBW2 Frg(v2) / Laundry Center
Frigidaire MLXE62RBW3 Frg(v2) / Laundry Center
Frigidaire MLXE62RBWD0 Kel(v10) / 27 " Electric Laundry Center
Frigidaire MLXE62RBWL0 Frg(v2) / 27 " Electric Laundry Center
Frigidaire MLXE62RBWW0 Frg(v1) / 27 " Electric Laundry Center
Frigidaire MLXE62RED0 Frg(v1) / Laundry Center
Frigidaire MLXE62RED3 Frg(v1) / Laundry Center
Frigidaire MLXE62REW0 Frg(v2) / Laundry Center
Frigidaire MLXE62REW1 Frg(v0) / Laundry Center
Frigidaire MLXE62REW2 Frg(v0) / Laundry Center
Frigidaire MLXE62REW3 Frg(v2) / Laundry Center
Frigidaire MLXG42RBD0 Kel(v10) / 27 " Gas Laundry Center
Frigidaire MLXG42RBD1 Gib(v1) / 27 " Gas Laundry Center
Frigidaire MLXG42RBD2 Frg(v1) / Laundry Center
Frigidaire MLXG42RBD3 Frg(v1) / Laundry Center
Frigidaire MLXG42RBW0 Tap(v4) / 27 " Gas Laundry Center
Frigidaire MLXG42RBW1 Gib(v2) / 27 " Gas Laundry Center
Frigidaire MLXG42RBW2 Frg(v2) / Laundry Center
Frigidaire MLXG42RBW3 Frg(v2) / Laundry Center
Frigidaire MLXG42RBWD0 Kel(v10) / 27 " Gas Laundry Center
Frigidaire MLXG42RBWL0 Frg(v2) / 27 " Gas Laundry Center
Frigidaire MLXG42RBWW0 Frg(v1) / 27 " Gas Laundry Center
Frigidaire MLXG42RED0 Frg(v1) / Laundry Center
Frigidaire MLXG42RED2 Frg(v1) / Laundry Center
Frigidaire MLXG42RED3 Frg(v1) / Laundry Center
Frigidaire MLXG42RED4 Frg(v1) / Laundry Center
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Stackable washer will not spin palladigma Dishwasher Repair 3 12-02-2009 06:39 AM
Estate Top Loading Washer Grinding spin cycle (Model year 2000?) fareall Washer Repair 1 08-31-2009 02:29 AM
stackable won't spin mwjwriter Washer Repair 0 07-30-2009 07:30 AM
Ack! Maytag Stackable Frontloader pnwpugmom Washer Repair 2 06-30-2008 12:59 PM
