washer agitates and fills and does everything but will not spin. put in new brake lining and still does not spin.Could it be because one of my belts is streched
OPerate it with the front cover off and see if you can tell what is going on. That should tell you if the problem is the motor not turning, the belt slipping or the transmission pulley not turning.
