I have a front load washer that only hums when you start it. What are the possible problems.
Originally Posted by: chris7969 I have a front load washer that only hums when you start it. What are the possible problems. We had the same issue and it was the belt in the back of the washer, it was shredded and wrapped around the motor. Hope this helps.
