When washer is finished and has gone through all cycles water drips into the tub.
You probably have grit in the water valve assembly and it is not letting the valve assembly close completely. change out the valve assembly and you should be all set.
Thank you for a fast reply.I will try the water valve. Thank you again. Jim
