washer run all cycles but when goes to spin it will not spin fast it only turns slow
With out the model number I can’t tell you much but if it is one of the new hydrowave washers it probably has an error code. Use this link to learn how the read and clear the code and how to repair the washer. http://www.appliance-repair-it.com/GE-washer-repair.html If not a hydrowave post model number or post model number and I will tell you if it is or not.
