Discuss
washing machine wont hold water
 in
Washer Repair
as the water is running in the washer it drains right through so nothing stays in and it doesnt leak
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washing machine wont hold water
  #1 (permalink)
Old 04-29-2009, 02:09 PM
Junior Member
daaalj6 is on a distinguished road
Default washing machine wont hold water
Brand: Crosley   Age: 1 - 5 years
as the water is running in the washer it drains right through so nothing stays in and it doesnt leak out on the floor or anything. and when it does fill and wash it wont fill again for the rinse cycle.
Ads By Google
  #2 (permalink)
Old 04-29-2009, 05:56 PM
Senior Member
applianceman is on a distinguished road
Default
Sounds like the water is siphoning out. This is caused by a few things one the drainpipe to your house is too low and you either need to extend the pipe up above the top of the tub or run the drain hose from you washer up high.
Another thing that can cause this is that someone taped the drain hose from the washer to the drainpipe to your house to stop the water from backing up. To fix this either clean out the drainpipe to your house and remove the tape or install a siphon break, part number 285320.
Last but not least if the drain hose from your washer is pushed down the drainpipe too far this will also cause the same problem. To fix just pull it out to about 6 inches of the end.
For more on do-it-yourself appliance repair help visit Appliance Repair Guide For All Major Home Appliances
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washing machine wont wash mieve Washer Repair 1 11-11-2009 12:09 PM
washing machine wont open Monisha Washer Repair 0 09-14-2009 11:48 AM
Washing Machine Wont Spin MoodyJudy3 Washer Repair 0 07-14-2008 09:56 AM
washing machine wont empty water angelasuco Washer Repair 0 06-20-2008 12:24 PM
Washer Wont hold water mlieber Washer Repair 1 10-14-2007 05:22 PM
