| » T bearing replacement |
Model Number: rax7245bw Brand: Whirlpool Age: More than 10 years
I need to remove a brake and drive tobe assembly on a wirlpool rax7245bw model washer And I do not know how to remove the thrust ring pn AP3018126 and the t-bearing pn AP3890496 can you help
You can get the proceedure to remove the spin tube assembly by reading my article in a "sticky" above "replacing direct drive washer brake shoes".
As noted, if you are working on the brake shoes, it is not necessary to remove the spin tube all the way. I use a flat blade screw driver to take off the "C" clips, and use pliers to put them back on.
__________________
Oh I see now, how in the whorld did this get messed up?? Personally, I would try putting some retaining marks on the end of the spin tube with a metal chisel, worth a try. Otherwise, you will need a new spin tube.
__________________
You need to read my sticky article to do this, get the spanner wrench, remove the agitator, loosten the drive block nut, pound down on it with a hammer while lifting up to get it free of the spin tube.
__________________
| Display Modes | |
| Hot Point Bearing Replacement | Hopefulnow | Dryer Repair | 2 | 02-08-2010 01:08 PM |
| Rear Bearing replacement | Randy Adams | Dryer Repair | 1 | 09-11-2009 01:40 PM |
| top bearing replacement | marcle | Dryer Repair | 1 | 08-01-2009 02:04 PM |
| Bearing Replacement | Tom F | Washer Repair | 1 | 05-05-2009 03:22 PM |
| Replacement of Tub Bearing | Augie | Washer Repair | 0 | 03-31-2009 03:01 PM |
