Discuss
washer will not spin or drain - leaks
 in
Washer Repair
My washer first started by making a loud noise when on the spin cycle. Now when on the spin cycle
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer will not spin or drain - leaks
  #1 (permalink)
Old 04-29-2009, 07:23 AM
Junior Member
BARCHER is on a distinguished road
Default washer will not spin or drain - leaks
Model Number: LNC6760B71   Brand: Maytag   Age: 1 - 5 years
My washer first started by making a loud noise when on the spin cycle. Now when on the spin cycle it does not spin up to speed. It moves very slow. If I turn by hand, it will start to get up to speed. When not spinning, the water does not drain. It has a slow leak at the bottom. Any ideas? Sounds like a it needs a Tub and seal kit.
Ads By Google
Related Models
Admiral LNC6760B71 Washer - Top Loading
International LNC6762A01 Washer - Top Loading
Admiral LNC6762A01 Washer - Top Loading
International LNC6762A71 Washer - Top Loading
Admiral LNC6762A71 Washer - Top Loading
International LNC6762A77 Washer - Top Loading
Admiral LNC6762A77 Washer - Top Loading
Admiral LNC6762B01 Washer - Top Loading
Admiral LNC6762B71 Washer - Top Loading
Admiral LNC6764A00 Washer - Top Loading
Admiral LNC6764A71 Washer - Top Loading
Admiral LNC6766A00 Washer - Top Loading
Admiral LNC6766A01 Washer - Top Loading
Admiral LNC6766A71 Washer - Top Loading
Admiral LNC6766A77 Washer - Top Loading
Admiral LNC6766B71 Washer - Top Loading
Admiral LNC7760A00 Dryer - Ele
Admiral LNC7760A71 Dryer - Ele
Admiral LNC7764A00 Dryer - Ele
Admiral LNC7764A71 Dryer - Ele
Admiral LNC7764A77 Dryer - Ele
Admiral LNC7766A00 Dryer - Ele
International LNC7766A00 Dryer - Ele
Admiral LNC7766A71 Dryer - Ele
International LNC7766A71 Dryer - Ele
Admiral LNC7766B71 Dryer - Ele
International LNC8760A00 Dryer - Gas
International LNC8760A01 Dryer - Gas
International LNC8760A71 Dryer - Gas
International LNC8760A77 Dryer - Gas
Admiral LNC8764A00 Dryer - Gas
Admiral LNC8764A71 Dryer - Gas
Admiral LNC8766A00 Dryer - Gas
International LNC8766A00 Dryer - Gas
Admiral LNC8766A71 Dryer - Gas
International LNC8766A71 Dryer - Gas
Admiral LNC8766B71 Dryer - Gas
Amana LP13300.A Mwave - Family Size (60 Hz)
Amana LP13300.B Mwave - Family Size (60 Hz)
Amana LP13600.A Mwave - Family Size (60 Hz)
Amana LP13600.B Mwave - Family Size (60 Hz)
Amana LP13610.A Mwave - Family Size (60 Hz)
Amana LP13610.B Mwave - Family Size (60 Hz)
Amana LP16400.A Mwave - Family Size (60 Hz)
Amana LP16400.B Mwave - Family Size (60 Hz)
Amana LP16600.A Mwave - Family Size (60 Hz)
Amana LP16600.B Mwave - Family Size (60 Hz)
Amana LP16610.A Mwave - Family Size (60 Hz)
Amana LP16610.B Mwave - Family Size (60 Hz)
Amana LP24400.A Mwave - Family Size (60 Hz)
Amana LP24400.B Mwave - Family Size (60 Hz)
Amana LP24600.A Mwave - Family Size (60 Hz)
Amana LP24600.B Mwave - Family Size (60 Hz)
Amana LP83400.A Mwave - Family Size (60 Hz)
Amana LP83400.B Mwave - Family Size (60 Hz)
Amana LP83430.A Mwave - Family Size (60 Hz)
Amana LP83430.B Mwave - Family Size (60 Hz)
Amana LP83600.A Mwave - Family Size (60 Hz)
Amana LP83600.B Mwave - Family Size (60 Hz)
Amana LP83620.A Mwave - Family Size (60 Hz)
Amana LP83630.A Mwave - Family Size (60 Hz)
Amana LP83630.B Mwave - Family Size (60 Hz)
Admiral LPK5404ARW Kitchen Compact
Admiral LPK5404ARZ Kitchen Compact
Admiral LPR1115ADW Range - F/s Std Gas
Whirlpool LPR4231AG0
Whirlpool LPR4231AN0
Whirlpool LPR4231AW0
Whirlpool LPR6244AN0
Whirlpool LPR6244AW0
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
Maytag LRTC15A Ref - Top Mount
  #2 (permalink)
Old 04-29-2009, 12:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the front panel and check inside for a water marks. Lift up the washer from the front, remove the belt and check how freely the pump pulley is rotating in both directions. Check the belt. Post the results.
Here are the breakdown diagrams and Replacement parts for ADMIRAL LNC6760B71 | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 04-29-2009, 01:29 PM
Junior Member
Default
Opened the washer up. Water is coming in from the bottom the tub. The belt has a small amount of play. Trying to repair, how do you get the inner tub out? I pulled out the four screws and the tub will not pull up.
  #4 (permalink)
Old 04-29-2009, 06:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hopefully this Service manual will help. Possible you'll need some special tools.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Washer Leaks at Drain Cycle ganzhimself Washer Repair 8 06-23-2010 03:09 AM
GE Washer, Loud Spin and Leaks Partmiser Washer Repair 1 10-29-2009 04:27 PM
washer leaks during spin cycle harryupson Washer Repair 1 10-04-2009 08:45 PM
kenmorre washer leaks on spin cycle only dcascino Washer Repair 5 11-14-2008 07:10 AM
washer both leaks and fails to fully drain mathias Washer Repair 4 08-05-2008 02:28 PM
