clicking noise a few wash cycles ago - now will not spin... I was going to ck out the agitator but do not know how to remove?
If it will not spin it is probably not the fault of the agitator, so you don't have to do anything about it. Take off the front cover and see if there are blinking lights on the motor. If so, these are error codes which you can interpret here. HydroWave GE Washer Repair GuideThe first thing you want to do is to reset it, sometimes that is all that is needed. My uninformed guess is that the mode shifter may have to be replaced.
judyt7652
(Washer Repair)
by judyt7652
12/20/2009 5:37:43 AM(UTC)
judy
(Washer Repair)
by whtiewidow
7/9/2009 8:40:22 PM(UTC)
