I have a Roper Brand washer model # RAX4232KQO, The wash cycle works fine, but whe it gets to the spin cycle, it wll not do anything. Can you give me some ideas as to what would make it do this?
Thanks in advance.
KStanley
Originally Posted by: kstanley I have a Roper Brand washer model # RAX4232KQO, The wash cycle works fine, but whe it gets to the spin cycle, it wll not do anything. Can you give me some ideas as to what would make it do this?
Thanks in advance.
KStanley K, I'm guessing the motor runs and the tub drains but does not spin. First open the lid and check for a small article stuck between the tub top and tub cover , or between the tubs. You'll need to remove the cabinet, pump and motor and check the motor coupler for damage (broken or bent legs/pegs) Part number: AP3963893
