yes hey am having problem get the machine to start..the lights comes on and all but sometimes it does start
Originally Posted by: marinda yes hey am having problem get the machine to start..the lights comes on and all but sometimes it does start Marinda, Are there no "error" codes in the display when the problem occurrs ? When you close the door and press the pause/resume button, the first thing should occurr is the door will lock and unlock, check for a door switch and possible spin issue, then lock the door and start to fill and wash. As your first check, you should probably check and make sure the door is aligned properly to the opening and the latch is enterring the latch opening properly. Good Luck, :) :) :)
