Discuss
washer floods
 in
Washer Repair
Help! washer just flooded my house! Water level did not shut off. I switched to small load, same thing. What
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer floods
  #1 (permalink)
Old 04-28-2009, 04:59 PM
Junior Member
fer kix is on a distinguished road
Default washer floods
Model Number: 110.26292692   Brand: Kenmore   Age: 5 - 10 years
Help! washer just flooded my house! Water level did not shut off. I switched to small load, same thing. What part do I need to replace (besides the entire unit). Is there a level indicator? Is it determined by weight? Maybe its the actual switch on the console? I dont know! Anybody help before I order parts at random?
Ads By Google
Related Models
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.48182790  AUTOMATIC WASHER
Kenmore 110.48182791  AUTOMATIC WASHER
Kenmore 110.48184790  AUTOMATIC WASHER
Kenmore 110.48184791  AUTOMATIC WASHER
Kenmore 110.48722790  COMPACT AUTOMATIC WASHER
Kenmore 110.48722791  COMPACT AUTOMATIC WASHER
Kenmore 110.48724790  COMPACT AUTOMATIC WASHER
Kenmore 110.48724791  COMPACT AUTOMATIC WASHER
Kenmore 110.49182990  AUTOMATIC WASHER
Kenmore 110.49182991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Kenmore 110.508802  KENMORE ELECTRIC DRYER
Kenmore 110.5807100  KENMORE GAS DRYER
Kenmore 110.5807300  KENMORE GAS DRYER
Kenmore 110.5807410  KENMORE GAS DRYER
Kenmore 110.5807500  KENMORE GAS DRYER
Kenmore 110.5807501  KENMORE GAS DRYER
Kenmore 110.5807700  KENMORE GAS DRYER
Kenmore 110.5807701  KENMORE GAS DRYER
Kenmore 110.5807800  KENMORE GAS DRYER
Kenmore 110.5807801  GAS DRYER
Kenmore 110.5807810  KENMORE GAS DRYER
Kenmore 110.5807811  KENMORE GAS DRYER
Kenmore 110.5807850  KENMORE GAS DRYER
Kenmore 110.5807851  GAS DRYER
Kenmore 110.5807860  KENMORE GAS DRYER
Kenmore 110.5807861  KENMORE GAS DRYER
Kenmore 110.5807950  KENMORE GAS DRYER
Kenmore 110.5807951  GAS DRYER
Kenmore 110.5807960  KENMORE GAS DRYER
Kenmore 110.5807961  KENMORE GAS DRYER
Kenmore 110.5808000  KENMORE ELECTRIC DRYER
Kenmore 110.5808010  KENMORE ELECTRIC DRYER
Kenmore 110.5808100  KENMORE ELECTRIC DRYER
  #2 (permalink)
Old 04-28-2009, 05:39 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Fer Kix
No you do not need to replace your machine, but we do need to have some more information before we can tell you what to do.
The question is does water come into you machine regardless of whether or not it is turned on, that is, when you open the valves to let hot and cold water into the machine, does it come into the machine even though you have not pulled out the control knob? In this situation the way of course you have to stop the water is to turn off the faucets.
Alternatively, does water continue into the tub only after you have started the machine, and the water does not stop unless you push in the control knob?
Also, does this happen with both hot and cold?
Just so you know, the way the water level works in your machine is that there is an air pressure switch which is activated by air trapped in a plastic tube. As the tub fills, pressure builds and when it reaches a certain point the water level switch is engaged and tells the timer the tub is filled. The timer then shuts off the inlet valves and starts to wash your clothes. If water comes on even if the machine is off, the problem is in your inlet valves, an easy fix. If water shuts off when you shut off the machine the problem is probably in your water level system, also an easy fix. Finally, the problem could be in the timer, which is unlikely. This is an easy, but more expensive fix.
Anyway, post the info and let's see what we have.
__________________
  #3 (permalink)
Old 04-29-2009, 05:26 AM
Junior Member
Default
Thanx for the reply! Just the kind of info I was looking for! I am a mechanic by trade, never had to repair a washer but as long as I know how it works, I can troubleshoot the problem more effectively. Yes, the water does shut off with the power off. As I turn the power on and off, the water flows accordingly, hot and cold. I hav'nt opened it up yet, just wanted some more info so as not to waste time.
  #4 (permalink)
Old 04-29-2009, 05:56 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is a good site with basic washer repair info which may be helpful
http://www.applianceaid.com/washers.html
__________________
  #5 (permalink)
Old 04-29-2009, 06:20 AM
Senior Expert
APP Volunteer
Default
Yes, that site is a good site, and it should give you some more info.
On your water level problem, once you open the machine you will see a plastic tube coming from the water level switich down the side of the tub . Check it for any leaks or any other problems and replace as needed. If it is ok, then replace the water level switch in the console and you should be fine.
Good luck and let us know how it turns out.
__________________
  #6 (permalink)
Old 04-29-2009, 06:54 AM
Junior Member
Default
Awsome info!! I thank you for your service! Great website!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washing machine floods garage bryce brown Washer Repair 1 02-10-2009 01:30 PM
Washer floods floor when filling sjburkett Washer Repair 1 01-27-2009 12:28 PM
Frigidaire PLD4555RFC Dishwasher floods Wyone Dishwasher Repair 1 12-02-2008 07:52 PM
Our KitchenAid Superba 21 floods the kitchen floor. dcoblentz Dishwasher Repair 1 11-28-2008 03:02 PM
washer floods brian6762 Washer Repair 1 11-26-2007 01:23 PM
