Discuss
kenmore elite he4t no power
 in
Washer Repair
hi,Our washer is getting power to the computer board, but has no lights on control panel and will not work
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore elite he4t no power
  #1 (permalink)
Old 12-06-2007, 12:47 PM
Junior Member
CAT88 is on a distinguished road
Default kenmore elite he4t no power
Model Number: 110.45981400   Brand: Kenmore   Age: 1 - 5 years
hi,Our washer is getting power to the computer board, but has no lights on control panel and will not work at all, Is there anything I can check for. Thanks for any help.Sincerely Craig
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 12-06-2007, 02:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Craig,
You can find all troubleshooting instructions in the technical data sheet.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-07-2007, 03:26 PM
Junior Member
Default Thanks Gene
Hi, well it looks like I will have to buy a cpu unit, No power coming out of computer board $150.00- $200.00 more into a $1300.00 dollar machine less than 3 years old. Thanks Craig
  #4 (permalink)
Old 12-07-2007, 04:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The part number for the Central Control Unit AP3881119 and you can buy it from APP for $144.56 (compare at $199.49 from Sears).
__________________
  #5 (permalink)
Old 12-31-2008, 12:27 PM
Junior Member
WJerry is on a distinguished road
Default
Hello - I am faced with this problem after installing the new control board (#8182221). Procedure so far: powered down machine, changed board, on power up I pressed cancel twice as instructed. The machine locked the door, flashed several lights and ended up with 3 dashes on the display. It would not respond to any further buttion pushing. I powered down the machine and manually unlocked the door. Repowered and it is now totally unresponsive. Any insight on what to do next ? Remember new control board.! Help....
Edited to add - Reinstalled old control board. Machine is now running and we are expecting more F11 and dL codes solved by wire wiggling. I'm guessing the new control board was defective.
  #6 (permalink)
Old 05-11-2009, 06:59 PM
Junior Member
lowlandman is on a distinguished road
Default cpu
How do I know if CPU is dead? I am getting the sam --- display others have mentioned.
  #7 (permalink)
Old 05-12-2009, 12:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
What is the complete model number of the washer?
__________________
  #8 (permalink)
Old 09-12-2009, 10:05 PM
Junior Member
richardson is on a distinguished road
Default Kenmore HE4t Washer fried during power outage
We had power outage for over 2 hours during a wash cycle for our Kenmore HE4t (model: 110.45986404) and now it will not power up. Dryer works fine and it's plugged into the same wall outlet. We unplug the washing machine and replugged. Still nothing. We had to manually opened to door to get our clothes out of the washer so they don't sit in the machine all wet. How do we drain the water inside the washer?
Any ideas on how to fix the power issue? I read the tech sheet posted above and we can hear power clicking to CCU.
Do we need to order a new CCU?
thank you!!!
  #9 (permalink)
Old 09-13-2009, 04:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Proceed with the steps 3 through 7 of "Possible cause/test", listed in the Tech sheet (page 14) for "Won't power up" problem and post the results.
__________________
  #10 (permalink)
Old 09-15-2009, 08:43 AM
Junior Member
Default
Gene,
We followed Steps 3-7, opened up the top, check all the connections. When we plug the power back, we can hear the clicking and very faint high pitch noise that rings for few seconds. No power to the LED/touch pad still.
We think maybe it's the control behind LED/touchpad is bad.
Any thoughts or help would be appreciated. Thank you!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite he4t f11 & fdl error codes glittleton Washer Repair 7 01-26-2013 02:09 PM
Kenmore elite power issue jjone45 Refrigerator & Freezer Repair 0 11-11-2009 04:52 AM
kenmore elite HE4t time flashes and wont run cycle cate rogers Washer Repair 1 06-26-2009 02:41 PM
kenmore elite HE4T raider24 Washer Repair 2 07-24-2008 08:56 AM
kenmore elite no power dexter777 Washer Repair 4 05-15-2008 09:00 PM
