Discuss
Washer will only drain if put on "Drain+Spin" cycle.
 in
Washer Repair
The title pretty much says it. But to reiterate, if the washer is put on regular wash it will not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will only drain if put on "Drain+Spin" cycle.
  #1 (permalink)
Old 10-05-2011, 06:15 PM
Junior Member
Arieleno is on a distinguished road
Default Washer will only drain if put on "Drain+Spin" cycle.
Model Number: 110.49722990   Brand: Kenmore   Age: 5 - 10 years
The title pretty much says it. But to reiterate, if the washer is put on regular wash it will not drain the water at the end of the cycle. However if you manually turn it to drain and spin, it will do its thing. Seems like maybe a timer problem to me, but I'd love to hear it from someone who knows more than me. Thanks!
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 10-07-2011, 06:35 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Since it will operate mechanically that does suggest the timer is at fault.
__________________
  #3 (permalink)
Old 10-23-2011, 08:38 AM
Junior Member
Default
Ok. Since the timer is a relatively expensive part, I would like to make sure before I order a new one. Is there a test I can do to confirm that the timer is bad?
  #4 (permalink)
Old 10-23-2011, 11:09 AM
Senior Expert
APP Volunteer
Default
Not really, but if you order from this site (we who respond are volunteers and not connected with the parts operations of APP. We recomend them as independents) and the part does not fix the problem you can return it.
See the returns policy for details and conditons, of which there are few.
Let us know how it turns out.
__________________
  #5 (permalink)
Old 10-24-2011, 07:14 PM
Junior Member
Default
I looked at the parts schematics and I couldn't come up with something referred to as a timer. I did find a part labelled "control board". Would that take the place of a mechanical timer on a newer unit? Considering what I have described as the problem, would that part make sense to replace?
  #6 (permalink)
Old 10-24-2011, 07:19 PM
Senior Expert
APP Volunteer
Default
When you said you manually turn it then it sounded like it has a timer. The control unit is electronic, so that is what you should try to change out to see if it will fix things.
__________________
  #7 (permalink)
Old 11-02-2011, 07:16 PM
Junior Member
Default
So I ordered and received the control board. I noticed when installing it that the unit was different. Most of the connections were the same but it was clearly an updated contol board. Needless to say this did not solve the problem. It may even be worse. Now when a wash cycle is chosen
It will not start, and with water stuck in the tub it won't drain when put on "drain", it only sloshes water around. Is it possible the control board wasn't to blame to begin with? And is it possible that the new control board doesn't work the same as the old one? I did retain the original control board in case the new one didn't work.
  #8 (permalink)
Old 11-02-2011, 08:03 PM
Senior Expert
APP Volunteer
Default
Those of us who respond on this Forum are not associated with the APP parts operations. I can only suggest you send it back to them, ask them to check the part and give them your model and serial numbers as sometimes parts of different for the same model.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile Washer - Loud "Jet Engine" sound during Spin Cycle AwesomeNovice Washer Repair 3 10-05-2011 11:53 AM
Washer does't drain and spin in a cycle and display "F" flashing Dragon838 Washer Repair 1 02-25-2011 04:36 AM
Washer doesn't drain and display "06 F" flashing Dragon838 Washer Repair 1 02-25-2011 04:35 AM
Kenmore 80 Series drops "lock" from drain to spin; spins while draining FalconFour Washer Repair 3 12-20-2010 07:14 AM
washer drain pump leaks. Center appears "burnt"/distorted piposos Washer Repair 8 12-06-2010 10:49 AM
