Discuss
Whirlpool Don't Work
 in
Washer Repair
Whirlpool won't run. Replaced lid switch because the internal contacts of the switch were melted and burned into the plastic
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Don't Work
  #1 (permalink)
Old 10-05-2011, 05:13 AM
Junior Member
BrokeDownNow is on a distinguished road
Default Whirlpool Don't Work
Model Number: LSW9750PW3   Brand: Whirlpool   Age: 1 - 5 years
Whirlpool won't run. Replaced lid switch because the internal contacts of the switch were melted and burned into the plastic switch housing. Replacing the lid switch still didn't fix the problem. Washer fills and then stops and won't agitate. Will not drain or spin if timer is manually moved to the spin cycle. What should I do to fix?
Ads By Google
Related Models
Whirlpool LSW9750PW3 Automatic Washer
Frigidaire LT150EXD2 Wwh(v1) / Tumble Action Washer
Frigidaire LT150EXF2 Wwh(v2) / Tumble Action Washer
Frigidaire LT150EXH2 Wwh(v3) / Tumble Action Washer
Frigidaire LT150EXV2 Wwh(v4) / Tumble Action Washer
Frigidaire LT150EXW2 Wwh(v5) / Tumble Action Washer
Frigidaire LT150JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT150JXF1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150JXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150JXV1 Wwh(v4) / Tumble Action Washer
Frigidaire LT150JXW1 Wwh(v5) / Tumble Action Washer
Frigidaire LT150LXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150LXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150LXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT200PXD2 Wwh(v2) / 27 " Front Load Washer
Frigidaire LT200PXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXW2 Wwh(v1) / 27 " Front Load Washer
Frigidaire LT250EXD2 Wwh(v6) / Tumble Action Washer
Frigidaire LT250EXD4 Wwh(v7) / Tumble Action Washer
Frigidaire LT250EXF2 Wwh(v8) / Tumble Action Washer
Frigidaire LT250EXF4 Wwh(v9) / Tumble Action Washer
Frigidaire LT250EXH2 Wwh(v10) / Tumble Action Washer
Frigidaire LT250EXH4 Wwh(v11) / Tumble Action Washer
Frigidaire LT250EXV2 Wwh(v12) / Tumble Action Washer
Frigidaire LT250EXV4 Wwh(v13) / Tumble Action Washer
Frigidaire LT250EXW2 Wwh(v14) / Tumble Action Washer
Frigidaire LT250EXW4 Wwh(v15) / Tumble Action Washer
Frigidaire LT250JXD1 Wwh(v6) / Tumble Action Washer
Frigidaire LT250JXF1 Wwh(v7) / Tumble Action Washer
Frigidaire LT250JXH1 Wwh(v8) / Tumble Action Washer
Frigidaire LT250JXV1 Wwh(v9) / Tumble Action Washer
Frigidaire LT250JXW1 Wwh(v10) / Tumble Action Washer
Frigidaire LT250LXD1 Wwh(v5) / Tumble Action Washer
Frigidaire LT250LXH1 Wwh(v6) / Tumble Action Washer
Frigidaire LT250LXW1 Wwh(v4) / Tumble Action Washer
Frigidaire LT350RXD1 Wwh(v2) / 27 " Front Load Washer
Frigidaire LT350RXW1 Wwh(v1) / 27 " Front Load Washer
Whirlpool LT4900XMW0
Whirlpool LT4900XMW1
Whirlpool LT4900XMW2
Whirlpool LT4900XSW1
Whirlpool LT4900XSW2
Whirlpool LT4900XSW3
Whirlpool LT4905XMW0
Whirlpool LT5000XLW0
Whirlpool LT5000XMW0
Whirlpool LT5000XMW1
Whirlpool LT5000XSW1
Whirlpool LT5000XSW2
Whirlpool LT5000XSW3
Whirlpool LT5000XVN0
Whirlpool LT5000XVW0
Whirlpool LT5004XMW0
Whirlpool LT5004XMW1
Whirlpool LT5004XSW1
Whirlpool LT5004XSW2
Whirlpool LT5004XSW3
Whirlpool LT5004XVN0
Whirlpool LT5004XVW0
Whirlpool LT5005XMW0
Whirlpool LT5009XMW0
Whirlpool LT5100XSW0
Whirlpool LT5100XSW1
Whirlpool LT5100XVN0
Whirlpool LT5100XVW0
Frigidaire LT600EXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT600EXD4 Wwh(v2) / Tumble Action Washer
Frigidaire LT600EXF1 Wwh(v3) / Tumble Action Washer
Frigidaire LT600EXF4 Wwh(v4) / Tumble Action Washer
Frigidaire LT600EXH1 Wwh(v5) / Tumble Action Washer
Frigidaire LT600EXH4 Wwh(v6) / Tumble Action Washer
Frigidaire LT600EXV1 Wwh(v7) / Tumble Action Washer
Frigidaire LT600EXV4 Wwh(v8) / Tumble Action Washer
Frigidaire LT600EXW1 Wwh(v9) / Tumble Action Washer
Frigidaire LT600EXW4 Wwh(v10) / Tumble Action Washer
Frigidaire LT600JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT600JXF1 Wwh(v2) / Tumble Action Washer
Frigidaire LT600JXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT600JXV1 Wwh(v4) / Tumble Action Washer
Frigidaire LT600JXW1 Wwh(v5) / Tumble Action Washer
Whirlpool LT7000XTF0
Whirlpool LT7000XTF1
Whirlpool LT7000XTG0
Whirlpool LT7000XTG1
Whirlpool LT7000XTM0
Whirlpool LT7000XTM1
Whirlpool LT7000XTN0
Whirlpool LT7000XTN1
Whirlpool LT7000XTW0
Whirlpool LT7000XTW1
Whirlpool LT7000XVN0
Whirlpool LT7000XVW0
Whirlpool LT7004XTF0
Whirlpool LT7004XTF1
Whirlpool LT7004XTG0
Whirlpool LT7004XTG1
Whirlpool LT7004XTM0
Whirlpool LT7004XTM1
Whirlpool LT7004XTN0
Whirlpool LT7004XTN1
Whirlpool LT7004XTW0
Whirlpool LT7004XTW1
Whirlpool LT7004XVW0
Frigidaire LT700EXD1 Wwh(v11) / Tumble Action Washer
Frigidaire LT700EXD4 Wwh(v12) / Tumble Action Washer
Frigidaire LT700EXD6 Wwh(v13) / Tumble Action Washer
Frigidaire LT700EXF1 Wwh(v14) / Tumble Action Washer
Frigidaire LT700EXF4 Wwh(v15) / Tumble Action Washer
Frigidaire LT700EXF6 Wwh(v16) / Tumble Action Washer
Frigidaire LT700EXH1 Wwh(v17) / Tumble Action Washer
Frigidaire LT700EXH4 Wwh(v18) / Tumble Action Washer
Frigidaire LT700EXH6 Wwh(v19) / Tumble Action Washer
Frigidaire LT700EXV1 Wwh(v20) / Tumble Action Washer
Frigidaire LT700EXV4 Wwh(v21) / Tumble Action Washer
Frigidaire LT700EXV6 Wwh(v22) / Tumble Action Washer
Frigidaire LT700EXW1 Wwh(v23) / Tumble Action Washer
Frigidaire LT700EXW4 Wwh(v24) / Tumble Action Washer
Frigidaire LT700EXW6 Wwh(v25) / Tumble Action Washer
Frigidaire LT700JXD1 Wwh(v6) / Tumble Action Washer
  #2 (permalink)
Old 10-05-2011, 07:02 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
BrokeDown,
Check the white and gray wire for damage and a circuit from the lid swit to the power corc(white wire) and to the motor teminals(gray wire) if the wiring is OK, check the timer circuits or replace the timer.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dishwasher won't work ohioriverrat Dishwasher Repair 0 08-23-2011 04:41 PM
Whirlpool icemaker doesn't work blutterflybird Refrigerator & Freezer Repair 1 03-04-2011 08:57 AM
Whirlpool AC won't work lemiley Heating, Ventilation, and Air Conditioning (HVAC) 11 09-18-2009 09:43 AM
whirlpool doesn't work charles sp davis Dishwasher Repair 1 01-29-2009 05:26 PM
whirlpool oven will not work charles e jimison Oven Repair (including Ranges and Cooktops) 1 01-24-2008 03:50 PM
