my washing machine works other than when it is filling up in the beginning, or when it fills again at the start of a new cylce, it will overflow with water:( Any ideas?
If you have to cut your water off the stop the water the water valve is bad and needs replacing. If unplugging the washer stops the water I would look at the water level control or the hose going to it. Clothes Washer Repair Guide
