Discuss
Washer lights flash; code e41
 in
Washer Repair
My washer runs about five minutes and then all the lights start flashing I press the pause and start buttons
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer lights flash; code e41
  #1 (permalink)
Old 04-27-2009, 06:36 PM
Junior Member
mebebrb is on a distinguished road
Default Washer lights flash; code e41
Model Number: GLTF2940ES0   Brand: Frigidaire   Age: 1 - 5 years
My washer runs about five minutes and then all the lights start flashing I press the pause and start buttons together and it give me an E41 error code. From the documentation I have found it thinks the door is open. I replaced the door switch/lock assembly and made it thru one load of laudry before it started happening again. I have made sure all the connectors are seated firmly. Any suggestions on where to look from here?
--Bruce
Related Models
Frigidaire GLTF2940ES0 Frigidaire/washer
Frigidaire GLTF2940ES1 Frigidaire/washer
Frigidaire GLTF2940ES2 Frigidaire/washer
Frigidaire GLTF2940ES3 Frigidaire/washer
Frigidaire GLTF2940FA2 WASHER
Frigidaire GLTF2940FE0 Frigidaire/washer
Frigidaire GLTF2940FE1 WASHER
Frigidaire GLTF2940FE2 WASHER
Frigidaire GLTF2940FS0 Frigidaire/washer
Frigidaire GLTF2940FS1 WASHER
Frigidaire GLTF2940FS2 WASHER
Frigidaire GLTF530DS0 Frigidaire/washer
Frigidaire GLTF530DS1 Frigidaire/washer
Frigidaire GLTR1670AS0 Frtld Wshr - Frigidaire Gallery
Frigidaire GLTR1670AS1 Frigidaire/washer
Frigidaire GLTR1670FS0 WASHER
Frigidaire GLTR1670FS1 WASHER
General Electric GLWN5050M0WS WASHER
General Electric GLWP2000M0WW WASHER
General Electric GLWP2000M1WW WASHER
Frigidaire GLWS1233AQ1 Washer - Frig Gallery
Frigidaire GLWS1233AQ2 Frigidaire/washer
Frigidaire GLWS1233AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1233AS1 Washer - Gallery
Frigidaire GLWS1233AS2 Frigidaire/washer
Frigidaire GLWS1233AS3 Frigidaire/washer
Frigidaire GLWS1339CC0 Frigidaire/washer
Frigidaire GLWS1339CS0 Frigidaire/washer
Frigidaire GLWS1339CS1 Frigidaire/washer
Frigidaire GLWS1339EC0 Frigidaire/washer
Frigidaire GLWS1339EC1 Frigidaire/washer
Frigidaire GLWS1339ES0 Frigidaire/washer
Frigidaire GLWS1339ES1 Frigidaire/washer
Frigidaire GLWS1349AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1349AS1 Washer - Frig Gallery
Frigidaire GLWS1439FC0 WASHER
Frigidaire GLWS1439FC1 WASHER
Frigidaire GLWS1439FC2 WASHER
Frigidaire GLWS1439FS0 WASHER
Frigidaire GLWS1439FS1 WASHER
Frigidaire GLWS1439FS2 WASHER
Frigidaire GLWS1649AS0 Washer - Frig Gallery
Frigidaire GLWS1649AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS2 Frigidaire/washer
Frigidaire GLWS1649AS4 Frigidaire/washer
Frigidaire GLWS1749AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1749AS2 Washer - Frig Gallery
Frigidaire GLWS1749AS4 Frigidaire/washer
Frigidaire GLWS1749AS5 Frigidaire/washer
Frigidaire GLWS1749FS0 WASHER
Frigidaire GLWS1749FS1 WASHER
Frigidaire GLWS1749FS2 WASHER
Frigidaire GLWS1939AS0 Frigidaire/washer
Frigidaire GLWS1939AS1 Frigidaire/washer
Frigidaire GLWS1979AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1979AS2 Washer - Frig Gallery
Frigidaire GLWS1979AS3 Frigidaire/washer
Frigidaire GLWY1343AS0 Frigidaire/washer
Frigidaire GLWY1343AS1 Frigidaire/washer
Gaggenau GM104-710
Gaggenau GM104-714
Admiral GM1110PRW RANGE- F/S STD GAS
Gaggenau GM215-721
Gaggenau GM215-760
Gaggenau GM215-761
Gaggenau GM286-710
Gaggenau GM286-720
Gaggenau GM286-760
Gaggenau GM288-710
Gaggenau GM288-714
Admiral GM3110MPAW RANGE- F/S STD GAS
Admiral GM3110MXAW RANGE- F/S STD GAS
Admiral GM3110PRAM RANGE- F/S STD GAS
Admiral GM3110PRWM RANGE- F/S STD GAS
Admiral GM31113WAM RANGE- F/S STD GAS
Admiral GM31113WAV RANGE- F/S STD GAS
Admiral GM3111GXAW RANGE- F/S STD GAS
Admiral GM3111SXAW RANGE- F/S STD GAS
Admiral GM31211XAW RANGE- F/S STD GAS
Admiral GM3167WUA RANGE- F/S STD GAS
Admiral GM3167WUV RANGE- F/S STD GAS
Admiral GM3210MXAW RANGE-F/S CONT CLEAN GAS
Admiral GM3211GXAA RANGE-F/S CONT CLEAN GAS
Admiral GM3211GXAW RANGE-F/S CONT CLEAN GAS
Admiral GM3211SXAA RANGE-F/S CONT CLEAN GAS
Admiral GM3211SXAW RANGE-F/S CONT CLEAN GAS
Admiral GM3216WRWM RANGE-F/S CONT CLEAN GAS
Admiral GM32211XAW RANGE-F/S CONT CLEAN GAS
Admiral GM3267WUAM RANGE-F/S CONT CLEAN GAS
Admiral GM3267WUWM RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUA RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUAM RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUW RANGE-F/S CONT CLEAN GAS
Admiral GM3267XUWM RANGE-F/S CONT CLEAN GAS
Gaggenau GM335-760
Maytag GM3468XUW-X RANGE- S/C F/S GAS
Admiral GM3510PRW RANGE- F/S STD ELE
Admiral GM3531WUV RANGE- S/C F/S ELE
Admiral GM3531WUW RANGE- S/C F/S ELE
Admiral GM3631XUA RANGE- F/S STD ELE
Admiral GM3631XUW RANGE- F/S STD ELE
Admiral GM3862XUW RANGE- S/C F/S ELE
Admiral GM3868XUA RANGE- S/C F/S ELE
Admiral GM3868XUW RANGE- S/C F/S ELE
Maytag GM4151WTA RANGE- F/S STD GAS
Maytag GM4151WTW RANGE- F/S STD GAS
Maytag GM4251WTA RANGE-F/S CONT CLEAN GAS
Maytag GM4251WTW RANGE-F/S CONT CLEAN GAS
Whirlpool GM8131XEB0 CONVECTION MICROWAVE OVEN
Whirlpool GM8131XEB1 MICROWAVE
Whirlpool GM8131XEQ0 CONVECTION MICROWAVE OVEN
Whirlpool GM8131XEQ1 MICROWAVE
Whirlpool GM8155XJB0 MICROWAVE-COUNTERTOP
Whirlpool GM8155XJB1 CONVECTION MICROWAVE OVEN
Whirlpool GM8155XJB2 CONVECTION MICROWAVE OVEN
Whirlpool GM8155XJQ0 MICROWAVE-COUNTERTOP
Whirlpool GM8155XJQ1 CONVECTION MICROWAVE OVEN
Whirlpool GM8155XJQ2 CONVECTION MICROWAVE OVEN
Whirlpool GM8155XJT0 MICROWAVE
Whirlpool GM8155XJT1 CONVECTION MICROWAVE OVEN
  #2 (permalink)
Old 04-28-2009, 05:50 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for FRG GLTF2940ES0 | AppliancePartsPros.com
Here is a tech sheet
ftp://ftp.electrolux-na.com/ProdInfo...08500wd_ts.pdf
As it says check that the switch is closing at the board.
Then if it is open replace the control board.
I would hate to see you replace the control board and not fix the problem!!
It ran once so the control board is probably OK.
Try unplugging the unit between loads, now does it run?
Could be the board is hanging up and when yo replaced the switch, you unplugged it, reset the board and that is why it ran once.
I would double check the door strike.
Perhaps try it while pushing on the door where the switch is.
Could be it is right on the edge of closing.
__________________
  #3 (permalink)
Old 04-28-2009, 06:22 AM
Junior Member
Default
Thanks for the info. I have tried unplugging between loads and that does not help (have tried that 3 or 4 times) I have tried leaning against the door while a load ran, that did not help either. A couple of times when the errors have a occured the switch/lock was still engaged and the door could not be opened so I don't "think" the door or the catch on the door are the problem.
  #4 (permalink)
Old 04-28-2009, 08:54 AM
Senior Expert
APP Volunteer
Default
Then all that is left is either the connecting wires or the control board.
__________________
  #5 (permalink)
Old 04-28-2009, 09:44 AM
Junior Member
Default
Thanks; guess I will dbl check the continuity on the wires and if that yields nothing I guess I order myself a control board (ouch).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen Aid Dishwasher control lights flash jhdean Dishwasher Repair 0 09-08-2009 12:34 PM
blue lights alternating flash Sherri22 Oven Repair (including Ranges and Cooktops) 0 06-30-2009 06:00 PM
Nothing Happens, All Lights flash Survivor Washer Repair 6 12-16-2008 05:05 PM
dishwasher will do nothing but flash lights holyhiker Dishwasher Repair 0 06-14-2008 08:12 AM
