Discuss
maytag washer will not fill with water
 in
Washer Repair
washer will run but will not fill with water is this a timer issue? yes the water is turned on
Appliance Repair Forum > Appliance Repair Help > Washer Repair » maytag washer will not fill with water
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-06-2007, 07:22 AM
wjim wjim is offline
Junior Member
wjim is on a distinguished road
Default maytag washer will not fill with water
Brand: Maytag   Age: 5 - 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-06-2007, 04:08 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to provide most accurate advise I need the complete model number of the washer.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-06-2007, 04:26 PM
Junior Member
Default Thanks for your reply
Thank you for replying I am out of town I will get back you this week-end.
  #4 (permalink)
Old 12-08-2007, 07:17 PM
Junior Member
Default model number
The Model number is LAT5910BAW.
Some additional info It runs through all the cycles without stopping but will not fill with water it does spin and agitate. hope this helps
wjim
  #5 (permalink)
Old 12-09-2007, 06:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would check is the water inlet valve (#32 on the cabinet break down diagram).
Check continuity across both coils terminals, replace the water inlet valve if any is open.
If there is nothing wrong, put the water temperature switch on "warm", start the washer and check for 120V to both coils. If there is no power coming, check wires and if this is not the issue, replace the timer (#18 on the control panel break down diagram).
- The part number for the timer AP253024
- The part number for the water inlet valve AP244856
- Here are the break down diagrams for the Maytag washer Model LAT5910BAW
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag washer neptune only put out warm or hot water no cold misterfixall Washer Repair 0 11-22-2007 03:16 PM
Maytag Washer No Water TimW Washer Repair 0 10-29-2007 06:24 AM
Maytag Washer Inlet valve - water level switch reisman Washer Repair 0 10-23-2007 08:36 PM
Water leak on front side of ice maker after fill trentrb211 Refrigerator & Freezer Repair 0 10-22-2007 10:53 AM
GE washer will not fill with water tex Dishwasher Repair 1 08-30-2007 11:33 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
