Washer fills, but will not agitate, drain or spin. Timer does not advance after washer fills. Lid switch was melted, so I replaced it, but that still did not make it run. Should I replace the timer or check something else? I don't want to buy a new timer and it still not fix the problem. Thanks.:eek:
The lid switch should have fixed things, although since you say it was melted that suggests some type of power surge. First try by-passing the lid switch, and if that does not fix things check out all the wiring and then if it still needs fixing try changing out the control unit.
