Discuss
Door Lock / Unlock Problem
 in
Washer Repair
[FONT='Verdana','sans-serif'] After pushing the start button, the door lock mechanism clicks, the door locks but a message on the LCD
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Door Lock / Unlock Problem
  #1 (permalink)
Old 10-04-2011, 08:56 AM
Junior Member
mceagle is on a distinguished road
Default Door Lock / Unlock Problem
Model Number: MAH7500AAW   Brand: Maytag   Age: 5 - 10 years
[FONT='Verdana','sans-serif']After pushing the start button, the door lock mechanism clicks, the door locks but a message on the LCD displays “The Door Did Not Appear to Lock – Make sure the door is shut” After tugging slightly on the door, another click is heard and the door unlocks. The LCD then displays “The door appeared locked unexpectedly, if problem persists…..” A few seconds after this, a short “buzz” is heard from the latch / lock mechanism, the LCD then displays “Door Locked” but the door in unlocked.[/font]
[FONT='Verdana','sans-serif'][/font]
[FONT='Verdana','sans-serif']In the diagnostic mode, the diagnostic codes #4 – Door fails to lock; #61 door locked early; #17 Door not opened. I then cleared the codes and attempted to re-start and basically the same occurred. Checked diagnostic code in service mode - #61 appeared. Ran the “Quick Spin Test” without issue after receiving a warning that the door was not locked.[/font]
[FONT='Verdana','sans-serif']I believe that I need to replace the Door Latch Assembly #22003593. Before ordering, I am seeking any advice / suggestion on any other diagnostics or possible issues. Thanks![/font]
Ads By Google
Related Models
Maytag MAH7500AWQ Washer - Horizontal Axis
Maytag MAH7500AWW Washer - Horizontal Axis
International MAH7550AAW Washer - Horizontal Axis
Maytag MAH7550AGW Washer - Horizontal Axis
International MAH7550AGW Washer - Horizontal Axis
Maytag MAH8700AWM Washer - Horizontal Axis
Maytag MAH8700AWW Washer - Horizontal Axis
Maytag MAH9700AWM Washer - Horizontal Axis
Maytag MAH9700AWQ Washer - Horizontal Axis
Maytag MAH9700AWW Washer - Horizontal Axis
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM Misc / Accessory
Maytag MAL1800AXQ Misc / Accessory
Maytag MAL1800AXW Misc / Accessory
Maytag MAL2000AXQ Misc / Accessory
Maytag MAL2000AXW Misc / Accessory
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL Washer - Top Loading
Maytag MAT10CSAAW Washer - Top Loading
Maytag MAT10CSAGL Washer - Top Loading
Maytag MAT10CSAGW Washer - Top Loading
Maytag MAT10CSBKL Washer - Top Loading
Maytag MAT10CSEGL Washer - Top Loading
Maytag MAT10CSEGW Washer - Top Loading
Maytag MAT10DAAAL Washer - Top Loading
Maytag MAT10DAAAW Washer - Top Loading
Maytag MAT10DAABL Washer - Top Loading
Maytag MAT10DAABW Washer - Top Loading
Maytag MAT10PDAAL Washer - Top Loading
Maytag MAT10PDAAW Washer - Top Loading
Maytag MAT10PDABL Washer - Top Loading
Maytag MAT10PDABW Washer - Top Loading
Maytag MAT10PDEGW Washer - Top Loading
Maytag MAT10PSAAL Washer - Top Loading
Maytag MAT10PSAAW Washer - Top Loading
Maytag MAT10PSAGL Washer - Top Loading
Maytag MAT10PSAGW Washer - Top Loading
Maytag MAT11CSBKL Washer - Top Loading
Maytag MAT11MNAAW Washer - Top Loading
Maytag MAT11MNAGW Washer - Top Loading
Maytag MAT11MNEGW Washer - Top Loading
Maytag MAT11PDAAL Washer - Top Loading
Maytag MAT11PDAAW Washer - Top Loading
Maytag MAT11PDABL Washer - Top Loading
Maytag MAT11PDABW Washer - Top Loading
Maytag MAT12CSAAL Washer - Top Loading
Maytag MAT12CSAAQ Washer - Top Loading
Maytag MAT12CSAAW Washer - Top Loading
Maytag MAT12CSAGW Washer - Top Loading
Maytag MAT12CSAKL Washer - Top Loading
Maytag MAT12CSAKQ Washer - Top Loading
Maytag MAT12CSDAQ Washer - Top Loading
Maytag MAT12CSDAW Washer - Top Loading
Maytag MAT12CSDGW Washer - Top Loading
Maytag MAT12CSEGW Washer - Top Loading
Maytag MAT12CSFWQ Washer - Top Loading
Maytag MAT12CSFWW Washer - Top Loading
Maytag MAT12PDAAL Washer - Top Loading
Maytag MAT12PDAAW Washer - Top Loading
Maytag MAT12PDABL Washer - Top Loading
Maytag MAT12PDABW Washer - Top Loading
Maytag MAT12PDAGW Washer - Top Loading
Maytag MAT12PDBAL Washer - Top Loading
Maytag MAT12PDBAQ Washer - Top Loading
Maytag MAT12PDBAW Washer - Top Loading
Maytag MAT12PDBBL Washer - Top Loading
Maytag MAT12PDBBQ Washer - Top Loading
Maytag MAT12PDBBW Washer - Top Loading
Maytag MAT12PDCBL Washer - Top Loading
Maytag MAT12PDCBQ Washer - Top Loading
Maytag MAT12PDCBW Washer - Top Loading
Maytag MAT12PDDAQ Washer - Top Loading
Maytag MAT12PDDAW Washer - Top Loading
Maytag MAT12PDDBW Washer - Top Loading
Maytag MAT12PDDGW Washer - Top Loading
Maytag MAT12PDEGW Washer - Top Loading
Maytag MAT12PDLAQ Washer - Top Loading
Maytag MAT12PDLAW Washer - Top Loading
Maytag MAT12PDLGW Washer - Top Loading
Maytag MAT12PDSAW Washer - Top Loading
Maytag MAT12PRAAW Washer - Top Loading
Maytag MAT12PRAEW Washer - Top Loading
Maytag MAT12PRBAW Washer - Top Loading
Maytag MAT12PRDAW Washer - Top Loading
Maytag MAT12PRSAW Washer - Top Loading
Maytag MAT12PSAAW Washer - Top Loading
Maytag MAT12PSAGW Washer - Top Loading
Maytag MAT12PSBAW Washer - Top Loading
Maytag MAT12PSDAW Washer - Top Loading
Maytag MAT12PSLWQ Washer - Top Loading
Maytag MAT12PSLWW Washer - Top Loading
Maytag MAT13MNAAW Washer - Top Loading
Maytag MAT13MNAGW Washer - Top Loading
Maytag MAT13MNDAW Washer - Top Loading
Maytag MAT13MNDGW Washer - Top Loading
Maytag MAT13MNEGW Washer - Top Loading
Maytag MAT13PDAAW Washer - Top Loading
Maytag MAT13PDBAW Washer - Top Loading
Maytag MAT13PNAEW Washer - Top Loading
Maytag MAT13PNDEW Washer - Top Loading
Maytag MAT13PRBWW Washer - Top Loading
Maytag MAT230CAAG Washer - Top Loading
Maytag MAT23PCAAC Washer - Top Loading
Maytag MAT23PCAAG Washer - Top Loading
Maytag MAT23PCAAL Washer - Top Loading
Maytag MAT23PCAAW Washer - Top Loading
Maytag MAT23PCABG Washer - Top Loading
Maytag MAT23PCABL Washer - Top Loading
Maytag MAT23PCABW Washer - Top Loading
Maytag MAT25CSAAG Washer - Top Loading
Maytag MAT25CSAAL Washer - Top Loading
Maytag MAT25CSAAW Washer - Top Loading
Maytag MAT25CSAGG Washer - Top Loading
Maytag MAT25CSAGL Washer - Top Loading
Maytag MAT25CSAGW Washer - Top Loading
Maytag MAT25CSBIL Washer - Top Loading
Maytag MAT25CSCAG Washer - Top Loading
Maytag MAT25CSCAL Washer - Top Loading
Maytag MAT25CSCAW Washer - Top Loading
Maytag MAT25CSEGG Washer - Top Loading
  #2 (permalink)
Old 10-06-2011, 06:48 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
You are probably right, but you will have to replace to be certain. Your control unit may also be the problem.
If you buy from this site and the part does not fix the problem you can return it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore oven door willnot lock or unlock 260wildcat Oven Repair (including Ranges and Cooktops) 0 01-03-2011 11:02 AM
Maytag Washer Door Lock Won't Unlock Alan Lieberman Washer Repair 2 07-24-2009 04:02 AM
Dishwasher key lock won't unlock (white) STEVE DOE Dishwasher Repair 12 10-02-2008 02:03 PM
self cleaning lock will not unlock- joycejas Oven Repair (including Ranges and Cooktops) 1 06-28-2008 09:16 AM
Duet door lock problem Fixshannon Washer Repair 0 09-14-2007 08:20 AM
