i ordered days ago a sensor for my whasher machine, but i can't do repair because the sensor's connector came without wires. somebody can help me?
What is the part number of the sensor you purchased?
The model number you posted does not come up. Verify and repost it please.
the part number i purchased is w10178988,make Whirlpool,the real mod number is wtw6200vw0, but i am thinking that other mod could be the same is wtw6600sw3. thanks.
There are no wires are attached to the sensor. There is a wire connector plug which has to be disconnected from the old sensor and plugged into the new one. The instructions are attached. Gene.
With people like you,Gene the technical problems doesn't exist. I solved the dificulties. I give you a AAA qualification.
thanks a lot.
You are welcome and thank you for your good words. I'm glad it's up and running.
