Discuss
Whirlpool washer weirdness
 in
Washer Repair
The old faithful Whirlpool toploader washer is acting up. I should probably just get a new one, but want to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer weirdness
  #1 (permalink)
Old 10-02-2011, 10:30 PM
Junior Member
Mr. Fixit-SB is on a distinguished road
Default Whirlpool washer weirdness
Model Number: LST7233AW0   Brand: Whirlpool   Age: More than 10 years
The old faithful Whirlpool toploader washer is acting up. I should probably just get a new one, but want to see if I can keep her out of the junk yard for a few more years. So... main timer knob has the following choices: 1. Regular, 2. Permanent Press 3. Super Wash 4. Delicate 5. Soak.
We usually run it on Regular, but recently it stopped draining after the wash cycle on Regular. So we started to just operate in on the Permanent Press option of the dial...and it worked just for for several months.
Now, my wife reports it doesn't agitate in the Permanent press option (but it drains and spins fine). So...regular cycle = no drain after wash, permanent press=no agitation (but drains/rinses/spins okay).
Seems to me the pump is fine (since it drains in permanent press mode), the lid switch is probably fine (since it spins okay). Maybe timer??
Any expert ideas out there?
Ads By Google
Related Models
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
Whirlpool LST8244DZ0
Whirlpool LST9245AN0
Whirlpool LST9245AW0
Whirlpool LST9245BN1
Whirlpool LST9245BQ0
Whirlpool LST9245BQ2
Whirlpool LST9245BW1
Whirlpool LST9245BZ0
Whirlpool LST9245BZ2
Whirlpool LST9355AN0
Whirlpool LST9355AW0
Whirlpool LST9355BN0
Whirlpool LST9355BQ0
Whirlpool LST9355BQ1
Whirlpool LST9355BW0
Whirlpool LST9355BZ0
Whirlpool LST9355BZ1
Whirlpool LST9355DQ0
Whirlpool LST9355DZ0
Whirlpool LSV5132AG0
Whirlpool LSV5132AN0
Whirlpool LSV5132AW0
Whirlpool LSV6233AG0
Whirlpool LSV6233AN0
Whirlpool LSV6233AW0
Whirlpool LSV6234AN0
Whirlpool LSV6234AW0
Whirlpool LSV7233BG0
Whirlpool LSV7233BN0
Whirlpool LSV7233BQ0
Whirlpool LSV7233BW0
Whirlpool LSV7233DQ0
Whirlpool LSV7233DZ0
Whirlpool LSV7244AN0
Whirlpool LSV7244AQ0
Whirlpool LSV7244AW0
Whirlpool LSV7245AN0
Whirlpool LSV7245AQ0
Whirlpool LSV7245AW0
Whirlpool LSV8244BN0
Whirlpool LSV8244BQ0
Whirlpool LSV8244BW0
Whirlpool LSV8244DQ0
Whirlpool LSV8244DZ0
Whirlpool LSV8245AN0
Whirlpool LSV8245AW0
Whirlpool LSV9244DQ0
Whirlpool LSV9244DZ0
Whirlpool LSV9245BN0
Whirlpool LSV9245BW0
Whirlpool LSV9355AN0
Whirlpool LSV9355AW0
Whirlpool LSV9355BN0
Whirlpool LSV9355BW0
Maytag LSW24A Ref - SXS/I&W
Whirlpool LSW9245EQ0
Whirlpool LSW9245EQ1
Whirlpool LSW9245EQ2
Whirlpool LSW9700PQ0 Automatic Washer
Whirlpool LSW9700PQ1 Automatic Washer
Whirlpool LSW9700PQ2 Automatic Washer
Whirlpool LSW9750PW0 Automatic Washer
Whirlpool LSW9750PW1 Automatic Washer
Whirlpool LSW9750PW2 Automatic Washer
Whirlpool LSW9750PW3 Automatic Washer
Frigidaire LT150EXD2 Wwh(v1) / Tumble Action Washer
Frigidaire LT150EXF2 Wwh(v2) / Tumble Action Washer
Frigidaire LT150EXH2 Wwh(v3) / Tumble Action Washer
Frigidaire LT150EXV2 Wwh(v4) / Tumble Action Washer
Frigidaire LT150EXW2 Wwh(v5) / Tumble Action Washer
Frigidaire LT150JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT150JXF1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150JXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150JXV1 Wwh(v4) / Tumble Action Washer
Frigidaire LT150JXW1 Wwh(v5) / Tumble Action Washer
Frigidaire LT150LXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150LXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150LXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT200PXD2 Wwh(v2) / 27 " Front Load Washer
Frigidaire LT200PXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXW2 Wwh(v1) / 27 " Front Load Washer
Frigidaire LT250EXD2 Wwh(v6) / Tumble Action Washer
Frigidaire LT250EXD4 Wwh(v7) / Tumble Action Washer
Frigidaire LT250EXF2 Wwh(v8) / Tumble Action Washer
Frigidaire LT250EXF4 Wwh(v9) / Tumble Action Washer
Frigidaire LT250EXH2 Wwh(v10) / Tumble Action Washer
Frigidaire LT250EXH4 Wwh(v11) / Tumble Action Washer
  #2 (permalink)
Old 10-03-2011, 07:59 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Sounds like it's time to replace the timer.
Part number: AP3605418
  #3 (permalink)
Old 10-03-2011, 09:53 PM
Junior Member
Default
Thanks! Are you pretty sure it's the timer?
That would have been my guess, since the issues were specific to a certain setting on the timer dial (e.g. no draining, but only on the "regular" setting). However, I poked around with the timer and watched it operate for a bit and it seemed like it was working okay (it looked pretty worn, in general. But so does the entire machine.) Again, hoping to keep it out of the junkyard as long as I can...as long as a fix is straightforward and I'm not buying parts I don't need like semi-expensive timers.
Thanks again for any advice.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burner Ignitor Weirdness! measinb Oven Repair (including Ranges and Cooktops) 0 03-25-2011 09:41 PM
Whirlpool stackable washer/dryer - washer advances cycles but takes a long time LynThereDoneThat Washer Repair 4 08-24-2010 07:38 PM
Whirlpool Washer lovelyuriah Washer Repair 0 03-17-2010 08:37 PM
Whirlpool washer rickado Washer Repair 1 10-29-2009 03:56 PM
Maytag MDG5500AWW Neptune dryer temperature control weirdness jwalker123 Dryer Repair 0 10-19-2009 11:11 PM
