Control panel turns on but when you push hold to start button, nothing happens. also the light that indicates which wash cycle you have chosen blinks instead of remaining solid.
The tech notes for this model should be under the top. It will show you how to put the machine into test mode.
If you cannot put it into test mode, the control unit is probably the problem.
Originally Posted by: sidfink43 The tech notes for this model should be under the top. It will show you how to put the machine into test mode.
If you cannot put it into test mode, the control unit is probably the problem. It will not go into test mode.
Then you will have to change out the control unit to see if that will fix things. If you buy from this site and the part does not fix the problem you can return it, see the returns policy for details and conditions.
Originally Posted by: sidfink43 Then you will have to change out the control unit to see if that will fix things. If you buy from this site and the part does not fix the problem you can return it, see the returns policy for details and conditions. Thank You will give it a try and see what happens.
