Discuss
Last cycle washer stops buzzing noise all cycles
 in
Washer Repair
My washing machine will not fill on last cycle. I hear an electrical sound and then buzzing. All cycles then
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Last cycle washer stops buzzing noise all cycles
  #1 (permalink)
Old 10-02-2011, 03:25 PM
Junior Member
rach is on a distinguished road
Default Last cycle washer stops buzzing noise all cycles
Model Number: LA5668WXTO   Brand: Whirlpool   Age: More than 10 years
My washing machine will not fill on last cycle. I hear an electrical sound and then buzzing. All cycles then either buzz or silent without working. I unplug and leave for a while and can get it to start on all but last cycle.
Ads By Google
Related Models
Whirlpool LA5668XSW0
Whirlpool LA5668XSW1
Whirlpool LA5668XSW2
Whirlpool LA5668XTF1
Whirlpool LA5668XTG1
Whirlpool LA5668XTM1
Whirlpool LA5668XTN1
Whirlpool LA5668XTW0
Whirlpool LA5668XTW1
Whirlpool LA5700XKW0 AUTOMATIC WASHER
Whirlpool LA5700XMW0 AUTOMATIC WASHER
Whirlpool LA5700XMW1 AUTOMATIC WASHER
Whirlpool LA5700XPW0 AUTOMATIC WASHER
Whirlpool LA5700XPW1 AUTOMATIC WASHER
Whirlpool LA5700XPW3 AUTOMATIC WASHER
Whirlpool LA5700XPW4 AUTOMATIC WASHER
Whirlpool LA5700XPW5 AUTOMATIC WASHER
Whirlpool LA5700XPW6 AUTOMATIC WASHER
Whirlpool LA5700XSW0 AUTOMATIC WASHER
Whirlpool LA5700XSW1 AUTOMATIC WASHER
Whirlpool LA5700XSW2 AUTOMATIC WASHER
Whirlpool LA5700XTF0
Whirlpool LA5700XTF1
Whirlpool LA5700XTG0
Whirlpool LA5700XTG1
Whirlpool LA5700XTM0
Whirlpool LA5700XTM1
Whirlpool LA5700XTN0
Whirlpool LA5700XTN1
Whirlpool LA5700XTW0 AUTOMATIC WASHER
Whirlpool LA5700XTW1 AUTOMATIC WASHER
Whirlpool LA5705XKW0 AUTOMATIC WASHER
Whirlpool LA5705XMW0 AUTOMATIC WASHER
Whirlpool LA5705XMW1 AUTOMATIC WASHER
Whirlpool LA5705XTF2
Whirlpool LA5705XTG2
Whirlpool LA5705XTM2
Whirlpool LA5705XTN2
Whirlpool LA5705XTW0 AUTOMATIC WASHER
Whirlpool LA5705XTW1 AUTOMATIC WASHER
Whirlpool LA5705XTW2 AUTOMATIC WASHER
Whirlpool LA5705XWF0
Whirlpool LA5705XWG0
Whirlpool LA5705XWM0
Whirlpool LA5705XWN0
Whirlpool LA5705XWW0 AUTOMATIC WASHER
Whirlpool LA5710XPW0 AUTOMATIC WASHER
Whirlpool LA5710XPW1 AUTOMATIC WASHER
Whirlpool LA5710XPW3 AUTOMATIC WASHER
Whirlpool LA5715XPW0 AUTOMATIC WASHER
Whirlpool LA5715XPW1 AUTOMATIC WASHER
Whirlpool LA5715XPW3 AUTOMATIC WASHER
Whirlpool LA5720XTF0
Whirlpool LA5720XTG0
Whirlpool LA5720XTM0
Whirlpool LA5720XTN0
Whirlpool LA5720XTW0 AUTOMATIC WASHER
Whirlpool LA5800XKW0
Whirlpool LA5800XMW0
Whirlpool LA5800XPW0
Whirlpool LA5800XPW1
Whirlpool LA5800XSW0
Whirlpool LA5800XSW1
Whirlpool LA5800XTF0
Whirlpool LA5800XTF1
Whirlpool LA5800XTG0
Whirlpool LA5800XTG1
Whirlpool LA5800XTM0
Whirlpool LA5800XTM1
Whirlpool LA5800XTN0
Whirlpool LA5800XTN1
Whirlpool LA5800XTW0
Whirlpool LA5800XTW1
Whirlpool LA5805XKW0
Whirlpool LA5805XMW0
Whirlpool LA5805XPW0
Whirlpool LA5805XPW1
Whirlpool LA5880XKW2
Maytag LA590 WASHER-TOP LOADING
Whirlpool LA5900XSW0
Whirlpool LA5900XSW1
Maytag LA5910 WASHER-TOP LOADING
Whirlpool LA5950XSW0
Whirlpool LA6000XPW0
Whirlpool LA6000XPW1
Whirlpool LA6000XPW2
Whirlpool LA6000XPW3
Whirlpool LA6000XPW4
Whirlpool LA6000XPW5
Whirlpool LA6000XSW0
Frigidaire LA600AXD1 Wwh(v6) / 27 " Washer
Frigidaire LA600AXD2 Wwh(v6) / 27 " Washer
Frigidaire LA600AXD3 Wwh(v1) / 27 " Washer
Frigidaire LA600AXW1 Wwh(v5) / 27 " Washer
Frigidaire LA600AXW2 Wwh(v5) / 27 " Washer
Frigidaire LA600AXW3 Wwh(v2) / 27 " Washer
Frigidaire LA600EXD3 Wwh(v11) / Top Loading Washer
Frigidaire LA600EXF3 Wwh(v12) / Top Loading Washer
Frigidaire LA600EXH3 Wwh(v13) / Top Loading Washer
Frigidaire LA600EXV3 Wwh(v14) / Top Loading Washer
Frigidaire LA600EXW3 Wwh(v15) / Top Loading Washer
Frigidaire LA600JXD3 Wwh(v1) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXD4 Wwh(v6) / Top Load Washer
Frigidaire LA600JXD5 Wwh(v3) / Top Load Washer
Frigidaire LA600JXF3 Wwh(v2) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXF4 Wwh(v7) / Top Load Washer
Frigidaire LA600JXH3 Wwh(v3) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXH4 Wwh(v8) / Top Load Washer
Frigidaire LA600JXV3 Wwh(v4) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXV4 Wwh(v9) / Top Load Washer
Frigidaire LA600JXW3 Wwh(v5) / Top Loading Automatic Agitator Washer
Frigidaire LA600JXW4 Wwh(v10) / Top Load Washer
Frigidaire LA600JXW5 Wwh(v4) / Top Load Washer
Frigidaire LA600MXD1 Wwh(v6) / 27 " Washer
Frigidaire LA600MXD2 Wwh(v6) / 27 " Washer
Frigidaire LA600MXH1 Wwh(v5) / 27 " Washer
Frigidaire LA600MXH2 Wwh(v5) / 27 " Washer
Frigidaire LA600MXW1 Wwh(v4) / 27 " Washer
Frigidaire LA600MXW2 Wwh(v4) / 27 " Washer
Whirlpool LA6010XTF0
  #2 (permalink)
Old 10-04-2011, 06:37 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Since it will go through the wash cycle ok, including the draining and spin the likely suspect is the control unit. Chagne it out and see if that fixes things.
__________________
  #3 (permalink)
Old 10-09-2011, 08:00 PM
Junior Member
Exclamation problem continues
Thanks, I did inspect timer control and gave it a shot of silicone spray in the back were the knob screw is. I seemed to feel it release in one area. However before doing that, as soon as Motor started buzzing I turned machine off and inspected Motor. It was to hot to touch. I removed start switch and found behind red casing black smudge. Hooked starter switch to a multimeter and found two out of the 3 tests failed. So before I can retest I have to decide if I want to purchase a new motor or just starter switch. Would a failed starter switch cause Motor to heat up so hot?
I was also hearing a thump on right side of machine mid way on cover now while in wash cycle. It was not doing that before. I had replaced motor couplers and cam dogs and may have not seated something correctly.
  #4 (permalink)
Old 10-10-2011, 02:42 PM
Senior Expert
APP Volunteer
Default
The motor should have a built in safety switch which shuts it down if it has a problem, so try just replacing the switch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer stops at different cycles kfoerster Washer Repair 4 09-26-2011 04:26 PM
washer stops between cycles ruthwilson Washer Repair 3 02-27-2011 12:16 PM
Washer Stops Between The Different Cycles ERICLM Washer Repair 1 08-01-2010 12:59 AM
Gas Dryer makes loud noise only in heat cycles not air fluff cycle repairneeded Dryer Repair 1 07-29-2010 05:09 PM
maytag washer stops during cycles wharkins Washer Repair 1 07-23-2009 04:45 PM
