Agitator cycle begins with hum, then shuts down. Spin cycle works. The agitator nut is flush and can't find a cap to remove for access to nut. How do you remove the agitator?
And what is the proper way to get front panel off? Panel has slotted tabs that appear to require somehow pushing the front panel lower to remove. Tried a block of wood under base but no movement when pushed.
