My Maytag SG1000 stackable washer appears to work but shuts off as control module calls for the motor to run then turns off.
I start my washer, it will fill then switches to a wash cycle. When the motor strarts it trys to run ( a little movement out of the motor) then the washer shuts down (all console lights go off/ shuts down). Is this a relay, motor switch?? Any ideas?
