My top part of my agitator only spins clockwise and not the back and forth motion. What part do I need to remedy this problem.
Thank you, Rodney
The top part is only supposed to go one direction. The bottom part goes back and forth. If you take the bottom part and move it back and forth you will see that the top moves in a clockwise direction to help push the clothes down towards the bottom agitator with larger sized loads. So, I am thinking everything is fine. If you want to investigate more search "replace agitator dogs Whirlpool" and you should find several videos that can help you determine if you have a problem and how to change them.
