Washer doesn't run. Get "sud" error and then F 35. What is wrong and what needs to be done to fix?
F35ANALOG PRESSURE SENSOR FAILURE If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board. 1. Check if pressure hose is fi xed correctly. 2. Check if the airtrap is not blocked. 3. Check if the hose is not blocked Whirlpool Duet Washer Fault Codes
