| » How Do I Remove The Agitator |
Model Number: WPSR3100W2WW Brand: GE Age: 5 - 10 years
My agitator only works when I fill the washer to a large wash load. If I fill it to a super load the bearings or something get wet and the top slips. I want to buy a new agitator, but I cant figure out how to get the old one out. Can anyone help me out with this problem? GE PROFILE MODEL# WPSR3100W2WW
Thank you, TWISTEDKEVIN Ads By Google Related Models |
Remove the dispenser assembly from the agitator and unscrew the bolt holding the agitator (#301 on the tub and agitator break down diagram).
The problem could be a worn out agitator coupling (#310 on the same break down diagram). - The part number for the agitator coupling AP3964635 - Here are the break down diagrams for the GE washer Model WPSR3100W2WW Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Thank you for your time Gene, But the agitator coupling seems to be working great. It's the top of the agitator that slips and does not go round & round, it just goes back & forth, if I fill it to high. I removed the dispenser and saw no nut, It's a sealed part. The agitator has to be removed in order to get to the bolt you talked about. I to thought it should be that easy! It's NEVER that easy is it? Could it just pull up and out?
Thank you, TWISTEDKEVIN |
In that case you just have to pull it up. It could be Very Hard!
__________________
It use to be a special tool, called "Agitamer". I'm afraid it's no longer available.
__________________
Thank you again for your time, I think I'll order the part and see what it looks like and try to get it out. If it works I'll let you know how I did it, maybe I'll use a tool called pounditout. Wish me luck!!
From cold Cleveland Ohio TWISTEDKEVIN |
| Display Modes | |
| Remove Agitator | PreachTC | Washer Repair | 3 | 03-04-2012 06:53 PM |
| Remove agitator | Larry225 | Washer Repair | 1 | 02-11-2010 06:28 PM |
| remove agitator | mdallen9 | Washer Repair | 0 | 02-07-2010 07:12 PM |
| How to remove agitator | kywoman43 | Washer Repair | 0 | 07-13-2009 09:14 AM |
| How to remove agitator? | Dobbsey | Washer Repair | 5 | 10-16-2008 03:25 PM |
