Discuss
Agitator slips
 in
Washer Repair
I have replaced the agitator "dogs" three times in the past 6 months, and it does not resolve my problem.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Agitator slips
  #1 (permalink)
Old 09-30-2011, 06:54 PM
Junior Member
JohnLyles is on a distinguished road
Default Agitator slips
Model Number: 110.20942994   Brand: Kenmore   Age: 5 - 10 years
I have replaced the agitator "dogs" three times in the past 6 months, and it does not resolve my problem. The agitator auger seems to fit very loosely onto the agitator base. I can move it from side to side about 1/2 inch. Because of this 1/2 inch of "play", the cam that holds the "dogs" randomly becomes slightly off-center inside the auger when the washer is running, and the "dogs" miss connecting with auger teeth. I just tested it with a load of clothes - the auger turned nicely for about 15 seconds, then started slipping for about 30 seconds. If I manually apply downward pressure to the top of the auger, it no longer slips. If I slightly tilt the auger to the side, it no longer slips. The cam's plastic screw with the spring is tightened completely. The washer is perfectly level. I just replaced the entire cam, dogs, screw, and spring yesterday. And today I replaced the auger spacer/washer that fits between the agitator base and the auger. I thought that perhaps a repairman had replaced my agitator auger with the wrong part number while I was on a business trip, but the part number is 8054498, just as the Kenmore diagram states. Could the auger's teeth be worn down? They appear to be rather sharp - not worn down. I am stumped. Shouldn't the cam fit somewhat snugly inside the auger - so that the "dogs" symmetrically connect with the auger teeth? Should I be able to wiggle the auger from side to side 1/2 inch while everything is tightened down? Why is this auger so loose????????????
Ads By Google
Related Models
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.48182790  AUTOMATIC WASHER
Kenmore 110.48182791  AUTOMATIC WASHER
Kenmore 110.48184790  AUTOMATIC WASHER
Kenmore 110.48184791  AUTOMATIC WASHER
Kenmore 110.48722790  COMPACT AUTOMATIC WASHER
Kenmore 110.48722791  COMPACT AUTOMATIC WASHER
Kenmore 110.48724790  COMPACT AUTOMATIC WASHER
Kenmore 110.48724791  COMPACT AUTOMATIC WASHER
Kenmore 110.49182990  AUTOMATIC WASHER
Kenmore 110.49182991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Kenmore 110.508802  KENMORE ELECTRIC DRYER
Kenmore 110.5807100  KENMORE GAS DRYER
Kenmore 110.5807300  KENMORE GAS DRYER
Kenmore 110.5807410  KENMORE GAS DRYER
Kenmore 110.5807500  KENMORE GAS DRYER
Kenmore 110.5807501  KENMORE GAS DRYER
Kenmore 110.5807700  KENMORE GAS DRYER
Kenmore 110.5807701  KENMORE GAS DRYER
Kenmore 110.5807800  KENMORE GAS DRYER
Kenmore 110.5807801  GAS DRYER
Kenmore 110.5807810  KENMORE GAS DRYER
Kenmore 110.5807811  KENMORE GAS DRYER
Kenmore 110.5807850  KENMORE GAS DRYER
Kenmore 110.5807851  GAS DRYER
Kenmore 110.5807860  KENMORE GAS DRYER
Kenmore 110.5807861  KENMORE GAS DRYER
Kenmore 110.5807950  KENMORE GAS DRYER
Kenmore 110.5807951  GAS DRYER
Kenmore 110.5807960  KENMORE GAS DRYER
  #2 (permalink)
Old 10-02-2011, 06:33 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Well everything you did should have fixed things. I have never seen a sitution where the teeth that the dogs engage have been worn.
It just sounds like it has not gone back together correctly, but I cannot tell anything is wrong from your description.
__________________
  #3 (permalink)
Old 10-03-2011, 07:02 AM
Junior Member
Default
It is put together correctly.
When the agitator auger is placed on top of the agitator, before the cam is inserted or the plastic screw and spring are tightened - should the auger have 1/2" of play from side to side? Or should it be a snug fit? The top of the agitator seems to be about 1/2" smaller in diameter than the diameter of the inside bottom of the auger. So what keeps the auger from wobbling around on the top of the agitator? This is my problem. Inside the bottom of the auger it appears to have some plastic fins around the entire circumference , but they are either worn down or broken off. Are these "fins" supposed to function as a "reducer" so that the auger fits snugly on top of the agitator?
  #4 (permalink)
Old 10-03-2011, 12:29 PM
Senior Expert
APP Volunteer
Default
The auger does fit tightly on top of the bottom piece of the agitator, so it sounds like either the top or bottom has something wrong with it. There should not be in play once everything is back together.
__________________
  #5 (permalink)
Old 10-04-2011, 05:50 AM
Junior Member
Default
I was hoping that someone at APP could look inside the bottom of a new 8054468 auger and see if these "fins" form a "reducer" that would fit snugly around the top of the agitator. Apparently not! I will order a new auger today from APP and post with the results.
  #6 (permalink)
Old 10-04-2011, 03:45 PM
Senior Expert
APP Volunteer
Default
John
Those of us who reply to posts on this Forum are not associated with APP. We are volunteers spread all over the country.
If you find you do not need the part you can return it to APP.
Good luck
__________________
  #7 (permalink)
Old 10-10-2011, 08:03 AM
Junior Member
Default
I received the new agitator auger as expected on Thursday, Oct 6. It looks 99.9% the same as the old/original auger, with the difference being signs of wear. BUT, this new auger does not wobble around during the wash cycle. It does not skip or miss, but rather it continuously spins and is very quiet. The original auger would miss, and make a slapping noise that was annoying. The $64,000 question: why did a new auger resolve the problem? I am using the same "dogs" as before, same everything except for the new auger. The original auger appears to be slightly out of round, and I mean VERY slightly. Bottom line: problem resolved.
  #8 (permalink)
Old 10-10-2011, 02:45 PM
Senior Expert
APP Volunteer
Default
Great, glad you got it fixed. As to the "why", I don't know. When I am lucky enough to get something fixed I don't ask questions, I just quietly leave.
Thanks for updating us.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frontload belt slips off timjmix11 Washer Repair 3 07-20-2010 05:25 PM
timer knob slips Gsdryer Dryer Repair 1 04-26-2009 01:13 PM
agitator skips/slips tschroeder Washer Repair 2 06-14-2008 12:31 PM
Kenmore washer 80 top agitator does not move with bottom agitator erbaker Washer Repair 1 02-19-2008 11:11 AM
agitator slips gvazquez Washer Repair 0 02-13-2008 09:17 AM
