Discuss
Whirlpool does not Drain or Spin
 in
Washer Repair
Top loading Whirlpool with no previous problems does not DRAIN or Spin. Timer functions in all cycles until gets to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool does not Drain or Spin
  #1 (permalink)
Old 04-26-2009, 07:35 AM
Junior Member
FLfix is on a distinguished road
Default Whirlpool does not Drain or Spin
Model Number: LSR7233Dq0   Brand: Whirlpool   Age: More than 10 years
Top loading Whirlpool with no previous problems does not DRAIN or Spin. Timer functions in all cycles until gets to drain and spin. Checked lid lever is intact, lid switch moves and checked by manuelly depressing no results. Removed clothes and tryed to have washer drain with no results. Remove most of the water and tryed to have it drain and spin no results. Any way to check for other issues or confirm function. Thank you.
Related Models
Whirlpool LSR7233DQ0 WASHER
Whirlpool LSR7233DQ1 AUTOMATIC WASHER
Whirlpool LSR7233DW0 WASHER
Whirlpool LSR7233DZ0 WASHER
Whirlpool LSR7233DZ1 AUTOMATIC WASHER
Whirlpool LSR7233EQ0 WASHER
Whirlpool LSR7233EQ1 AUTOMATIC WASHER
Whirlpool LSR7233EW0 DIRECT-DRIVE WASHER
Whirlpool LSR7233EZ0 DIRECT-DRIVE WASHER
Whirlpool LSR7233EZ1 AUTOMATIC WASHER
Whirlpool LSR7233HQ0 AUTOMATIC WASHER
Whirlpool LSR7233HZ0 AUTOMATIC WASHER
Whirlpool LSR7300PQ0 AUTOMATIC WASHER
Whirlpool LSR7300PQ1 AUTOMATIC WASHER
Whirlpool LSR7300PQ2 AUTOMATIC WASHER
Whirlpool LSR7333PQ0 AUTOMATIC WASHER
Whirlpool LSR7333PQ1 AUTOMATIC WASHER
Whirlpool LSR7333PQ3 AUTOMATIC WASHER
Whirlpool LSR7333PQ4 AUTOMATIC WASHER
Whirlpool LSR8010PQ0 AUTOMATIC WASHER
Whirlpool LSR8010PQ1 AUTOMATIC WASHER
Whirlpool LSR8010PQ2 AUTOMATIC WASHER
Whirlpool LSR8010PT0 AUTOMATIC WASHER
Whirlpool LSR8010PT1 AUTOMATIC WASHER
Whirlpool LSR8010PT2 AUTOMATIC WASHER
Whirlpool LSR8133HQ0 AUTOMATIC WASHER
Whirlpool LSR8133HZ0 AUTOMATIC WASHER
Whirlpool LSR8200EQ0 AUTOMATIC WASHER
Whirlpool LSR8200EZ0 AUTOMATIC WASHER
Whirlpool LSR8233EQ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EQ1 AUTOMATIC WASHER
Whirlpool LSR8233EZ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EZ1 AUTOMATIC WASHER
Whirlpool LSR8233JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JQ1 WASHER
Whirlpool LSR8233JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JT1 WASHER
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0 WASHER
Whirlpool LSR8433KQ1 AUTOMATIC WASHER
Whirlpool LSR8433KQ2 AUTOMATIC WASHER
Whirlpool LSR8433KT0 WASHER
Whirlpool LSR8433KT1 AUTOMATIC WASHER
Whirlpool LSR8433KT2 AUTOMATIC WASHER
Whirlpool LSR8444LQ0 WASHER
Whirlpool LSR8444LQ1 AUTOMATIC WASHER
Whirlpool LSR8444LT0 WASHER
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 AUTOMATIC WASHER
Whirlpool LSR9434PQ1 AUTOMATIC WASHER
Whirlpool LSR9434PQ3 AUTOMATIC WASHER
Whirlpool LSR9434PQ4 AUTOMATIC WASHER
Whirlpool LSR9434PT0 AUTOMATIC WASHER
Whirlpool LSR9434PT1 AUTOMATIC WASHER
Whirlpool LSR9434PT3 AUTOMATIC WASHER
Whirlpool LSR9434PT4 AUTOMATIC WASHER
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
General Electric LSS25XSWASS REFRIGERATOR W SERIES
General Electric LSS25XSWCSS REFRIGERATOR W SERIES
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0 WASHER
Whirlpool LSS9244EZ0 WASHER
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
  #2 (permalink)
Old 04-26-2009, 10:14 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
You are right to suspect the lid switich, but you cannot give it a good test by simply depressing the switch, as it could have an internal break which would not be detected.
To fully test the lid switch you are going to need to disconnect the power, undo the two screws that hold the console down, flip it up and back and then disconnect the plastic connector that goes into the cabinet. On the part of the connector that comes from the console you will want to insert a short u shaped piece of insulated solid wire into the outer two terminals. This will by pass the lid switch. You can then plug in the machine, set the timer on spin and engage the machine. If it spins your lid switch is bad and will need to be replaced.
Let us know the results, and if you find it is not the switch we will go on to the next suspect in the lineup.
__________________
  #3 (permalink)
Old 04-26-2009, 04:29 PM
Senior Expert
APP Volunteer
Default
Ignore that, I am afraid someone has crashed the site.
__________________
  #4 (permalink)
Old 04-27-2009, 07:37 AM
Junior Member
Default
Sir, I did the lid switch function test per your instruction. By using the jumper wire the washer will now drain and spin. So I believe that the lid switch will be neccessary. Am I correct?
  #5 (permalink)
Old 04-27-2009, 08:14 AM
Senior Expert
APP Volunteer
Default
Correct, and congratulations on finding the problem.
Here is your replacement part.
Replacement parts for WHIRLPOOL LSR7233DQ0 | AppliancePartsPros.com
You can remove the cabinet by popping out the brass looking clips at each side of the top of the cabinet with a flat blade screw driver, then pulling the cabinet up and towards you. This will give you access to the switch.
Good luck
__________________
  #6 (permalink)
Old 04-27-2009, 08:20 AM
Junior Member
Default
Ordered the part and I wish to THANK YOU VERY MUCH for the assistance!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool washer will not drain or spin llbishop7@cs.com Washer Repair 3 08-17-2012 03:24 PM
whirlpool won't drain/spin joshcarguy Washer Repair 1 01-30-2010 04:43 PM
Whirlpool washer won't drain or spin KellaC32 Washer Repair 3 12-02-2009 10:37 AM
whirlpool will not drain or spin mauriceiera@yahoo.com Washer Repair 4 11-26-2009 09:32 PM
whirlpool stackable does not spin and drain luv2gtnkd Washer Repair 2 07-02-2009 12:10 PM
