Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Maytag leaking during spin cycle (http://forum.appliancepartspros.com/washer-repair/31469-maytag-leaking-during-spin-cycle.html)
red574 04-24-2009 05:43 PM
I have a Maytag Neptune washer that I repaired in February. I replaced the bearings and seal. Now the washer is leaking during the spin cycle. What needs to be replaced and how much trouble is it?
Regards,
RED
red574 04-24-2009 07:34 PM
I found the problem. The drian hose came off the inner door boot. I attached the drain hose and clamp. It does not leak.
RED
neptune help 04-25-2009 03:04 PM
Hello, make sure that you replace your faulty door latch wax motor if you have not done so yet. See MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT + 12002535 WAX MOTOR for details. There is a video at MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT + 12002535 WAX MOTOR that explains the issue. Also, the earlier MAH3000's have (2) more of the faulty wax motors in the soap dispenser that will fail eventually. These control the softener and bleach flow.
