Discuss
Washing machine will not spin during rinse cycle
 in
Washer Repair
Washing machine will not spin, I thought it was a problem with the drive belt; but found out that this
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washing machine will not spin during rinse cycle
  #1 (permalink)
Old 04-24-2009, 03:16 PM
crookster crookster is offline
Junior Member
crookster is on a distinguished road
Default Washing machine will not spin during rinse cycle
Model Number: LA5580XTW0   Brand: Whirlpool   Age: More than 10 years
Washing machine will not spin, I thought it was a problem with the drive belt; but found out that this model does not have a drive belt since it is direct drive. Machine was purchased 16 years ago, but was only used for a year; it was then stored in my garage until about a year and half ago. In short, the machine has only been used for about two and a half years. Please help.
Dave
Related Models
Whirlpool LA5580XTW0
Whirlpool LA5580XTW1
Whirlpool LA5588XYG0
Whirlpool LA5588XYN0
Whirlpool LA5588XYW0
Whirlpool LA5590XPW0
Whirlpool LA5590XPW1
Whirlpool LA5591XPW3
Whirlpool LA5591XPW4
Whirlpool LA5599XPW4
Whirlpool LA5600XKW0
Whirlpool LA5600XKW1
Whirlpool LA5600XKW2
Whirlpool LA5600XMW0
Whirlpool LA5600XPW0
Whirlpool LA5600XPW1
Whirlpool LA5600XPW3
Whirlpool LA5600XPW4
Whirlpool LA5600XPW5
Whirlpool LA5600XPW6
Whirlpool LA5600XPW7
Whirlpool LA5600XSW0
Whirlpool LA5600XSW1
Whirlpool LA5600XSW2
Whirlpool LA5600XTF0
Whirlpool LA5600XTF1
Whirlpool LA5600XTG0
Whirlpool LA5600XTG1
Whirlpool LA5600XTM0
Whirlpool LA5600XTM1
Whirlpool LA5600XTN0
Whirlpool LA5600XTN1
Whirlpool LA5600XTW0
Whirlpool LA5600XTW1
Whirlpool LA5605XKW1
Frigidaire LA560AXD1 Wwh(v6) / 27 " Washer
Frigidaire LA560AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA560AXW1 Wwh(v5) / 27 " Washer
Frigidaire LA560AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA560JXD3 Wwh(v1) / Washer
Frigidaire LA560JXD4 Wwh(v1) / Top Load Washer
Frigidaire LA560JXD5 Wwh(v1) / Top Load Washer
Frigidaire LA560JXF3 Wwh(v2) / Washer
Frigidaire LA560JXF4 Wwh(v2) / Top Load Washer
Frigidaire LA560JXH3 Wwh(v3) / Washer
Frigidaire LA560JXH4 Wwh(v3) / Top Load Washer
Frigidaire LA560JXV3 Wwh(v4) / Washer
Frigidaire LA560JXV4 Wwh(v4) / Top Load Washer
Frigidaire LA560JXW3 Wwh(v5) / Washer
Frigidaire LA560JXW4 Wwh(v5) / Top Load Washer
Frigidaire LA560JXW5 Wwh(v2) / Top Load Washer
Frigidaire LA560MXD1 Wwh(v3) / 27 " Washer
Frigidaire LA560MXD2 Wwh(v2) / 27 " Washer
Frigidaire LA560MXH2 Wwh(v3) / 27 " Washer
Frigidaire LA560MXW1 Wwh(v1) / 27 " Washer
Frigidaire LA560MXW2 Wwh(v1) / 27 " Washer
Whirlpool LA5610XTF0
Whirlpool LA5610XTG0
Whirlpool LA5610XTG1
Whirlpool LA5610XTM0
Whirlpool LA5610XTN0
Whirlpool LA5610XTN1
Whirlpool LA5610XTW0
Whirlpool LA5610XTW1
Whirlpool LA5668XSW0
Whirlpool LA5668XSW1
Whirlpool LA5668XSW2
Whirlpool LA5668XTF1
Whirlpool LA5668XTG1
Whirlpool LA5668XTM1
Whirlpool LA5668XTN1
Whirlpool LA5668XTW0
Whirlpool LA5668XTW1
Whirlpool LA5700XKW0
Whirlpool LA5700XMW0
Whirlpool LA5700XMW1
Whirlpool LA5700XPW0
Whirlpool LA5700XPW1
Whirlpool LA5700XPW3
Whirlpool LA5700XPW4
Whirlpool LA5700XPW5
Whirlpool LA5700XPW6
Whirlpool LA5700XSW0
Whirlpool LA5700XSW1
Whirlpool LA5700XSW2
Whirlpool LA5700XTF0
Whirlpool LA5700XTF1
Whirlpool LA5700XTG0
Whirlpool LA5700XTG1
Whirlpool LA5700XTM0
Whirlpool LA5700XTM1
Whirlpool LA5700XTN0
Whirlpool LA5700XTN1
Whirlpool LA5700XTW0
Whirlpool LA5700XTW1
Whirlpool LA5705XKW0
Whirlpool LA5705XMW0
Whirlpool LA5705XMW1
Whirlpool LA5705XTF0
Whirlpool LA5705XTF1
Whirlpool LA5705XTF2
Whirlpool LA5705XTG0
Whirlpool LA5705XTG1
Whirlpool LA5705XTG2
Whirlpool LA5705XTM0
Whirlpool LA5705XTM1
Whirlpool LA5705XTM2
Whirlpool LA5705XTN0
Whirlpool LA5705XTN1
Whirlpool LA5705XTN2
Whirlpool LA5705XTW0
Whirlpool LA5705XTW1
Whirlpool LA5705XTW2
Whirlpool LA5705XWF0
Whirlpool LA5705XWG0
Whirlpool LA5705XWM0
Whirlpool LA5705XWN0
Whirlpool LA5705XWW0
Whirlpool LA5710XPW0
Whirlpool LA5710XPW1
  #2 (permalink)
Old 04-25-2009, 06:47 PM
sidfink43 sidfink43 is online now
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Can you give us a little more information
1. Does it spin after the wash cycle but not after the rinse cycle?
2. Does it drain after the wash cycle and after the rinse cycle?
3. When it is not spinning, can you hear the motor running?
4. Does the timer advance in the spin cycle when it is not spinning?
Please provide any other info you think will help and let's see what this tells us. Thanks
__________________
  #3 (permalink)
Old 04-27-2009, 07:57 AM
Junior Member
Default
Yes it spins after the wash cycle but not after rinse.
Yes it drains after the wash cycle and rinse cycle.
Yes I can hear the motor running when it is not spinning.
Yes the timer advances in the spin cycle when not spinning.
  #4 (permalink)
Old 04-27-2009, 09:22 AM
Senior Expert
APP Volunteer
Default
Ok, here is what I would like you to do.
With no clothes, set the washer timer on rinse with low water level and let it fill up and go through the rinse cycle. After you hear all of the water has drained out, about 90 seconds to 2 minutes, lift the lid and hold it open for about 5 seconds. Then close the lid.
If the machine goes into a spin at this time, the problem is probably in your timer. Basically, the timer has to tell the motor to pause briefly after the water has flowed out of the machine, and your timer is failing to do so. Lifting the lid artificially creates this pause and if this is the problem the machine should now go into spin mode.
Here is your timer
Replacement parts for WHIRLPOOL LA5580XTW0 | AppliancePartsPros.com
If lifting the lid and creating the pause does not work to start spin mode, please post and let's see what else we can come up with.
Good luck
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washing Machine won't go through rinse cycle rlaverne38 Washer Repair 2 03-26-2009 04:27 PM
Washing machine spin cycle off balance Mike Diven Washer Repair 4 01-03-2009 11:30 PM
Roper washing machine shakes during spin cycle... zoe1594 Washer Repair 3 06-09-2008 01:22 PM
Washing machine spin cycle does not work pamilyas@gmail.com Washer Repair 9 05-17-2008 11:54 AM
Roper washing machine stuck in spin cycle jskogsberg Dishwasher Repair 3 02-08-2008 12:56 PM
