| » FRIGIDAIRE no final spin |
Model Number: LTF2140ES3 Brand: Frigidaire Age: 1 - 5 years
I have a front load washer that will go through all cycles but will not do the final spin. I am very handy with fixing stuff so I just assumed a belt or gear box. I found the belt in tack and no drive-train troubles. I used a shop vac to pull all of the water out of the pump but that did not seem to fix the problem. Although I was able to get it to final spin one time.
I removed the pump and it is very noisy but still has all of the vanes and runs just fine and does not slip on the shaft when I put pressure on it while it is spinning. I'm guessing it's the door latch switch. I've read to check it with a multi-meter .. But I don't know what values are good .. Please point me in the right direction. Thanks .. K Ads By Google Related Models |
I take it the unit is not draining the water these machines are equipped with a pressure switch and will not go into spin until the water has been drained. ok if you look at the hose that connects the tub to the pump there is a filter in there. pull this filter out and clean it,its a clear plastic. Make sure to put the filter back in correctly. I have seen them put back in wrong and get sucked into the tub and cause some damage.
| Display Modes | |
| Frigidaire washer won't do final fast spin | BH11 | Washer Repair | 0 | 09-28-2011 06:36 AM |
| Frigidaire front load washer will not final spin | tap1168 | Washer Repair | 1 | 04-14-2011 07:03 PM |
| Frigidaire Front Loader won't do final spin | digitalslacker | Washer Repair | 4 | 07-12-2010 05:41 PM |
| frigidaire front load washer will not go into final spin | cubbie23 | Washer Repair | 2 | 02-12-2010 12:40 PM |
| front load frigidaire will not spin on final | Danmav | Washer Repair | 3 | 12-03-2009 04:24 PM |
