My Frigidaire front loading washer appears to perform all of the functions as it should, until it reaches the final high speed rinse. It goes through all of the processes with the time remaining displayed. It also shows that the door is locked. However, when it gets to about 7-8 minutes remaining, it just cuts off. I am not receiving any error messages. I have verified that it is draining correctly (I replaced the pump within the past year). It will agitate, and all of the belts look good. Does anyone have any idea what the problem could be?
