Discuss
Washer won't drain or spin
 in
Washer Repair
My Washer won't Spin or drain at all. It fills fine and washes and thats all it will do
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't drain or spin
  #1 (permalink)
Old 04-24-2009, 05:21 AM
Dawna Dawna is offline
Junior Member
Dawna is on a distinguished road
Default Washer won't drain or spin
Model Number: L5Q9544KQ0   Brand: Whirlpool   Age: 5 - 10 years
My Washer won't Spin or drain at all. It fills fine and washes and thats all it will do now..
Related Models
Norge L6892VRV Range - S/c S/i Ele
Norge L6892VVV Range - S/c S/i Ele
Norge L6892VYV Range - S/c S/i Ele
Norge L6898VYV Range - S/c S/i Ele
Norge L6898XYB Range - S/c S/i Ele
Norge L6898XYV Range - S/c S/i Ele
Norge L8610PV Surface Unit - Ele
Norge L8610RV Surface Unit - Ele
Norge L8660PB Surface Unit - Ele
Norge L9844VPV Walloven - S/c Ele
Norge L9844XPB Walloven - S/c Ele
Norge L9845XUB Walloven - S/c Ele
Norge L9875VRV Walloven - S/c Ele
Norge L9875VVV Walloven - S/c Ele
Norge L9875XRB Walloven - S/c Ele
Norge L9875XVB Walloven - S/c Ele
Maytag LA104 Washer - Top Loading
Maytag LA105 Washer - Top Loading
Maytag LA105T Washer - Top Loading
Maytag LA107 Washer - Top Loading
Maytag LA107S Washer - Top Loading
Maytag LA108 Washer - Top Loading
Maytag LA110 Washer - Top Loading
Maytag LA112 Washer - Top Loading
Maytag LA112T Washer - Top Loading
Amana LA12300.A Mwave - Family Size (60 Hz)
Amana LA12600.A Mwave - Family Size (60 Hz)
Amana LA12610.A Mwave - Family Size (60 Hz)
Amana LA15300.A Mwave - Family Size (60 Hz)
Amana LA15500.A Mwave - Family Size (60 Hz)
Amana LA15600.A Mwave - Family Size (60 Hz)
Amana LA15610.A Mwave - Family Size (60 Hz)
Amana LA15700.A Mwave - Family Size (60 Hz)
Maytag LA180 Washer - Top Loading
Maytag LA181 Washer - Top Loading
Maytag LA182 Washer - Top Loading
Maytag LA183 Washer - Top Loading
Maytag LA183T Washer - Top Loading
Maytag LA190 Washer - Top Loading
Maytag LA190T Washer - Top Loading
Maytag LA1910 Washer - Top Loading
Maytag LA200 Washer - Top Loading
Admiral LA2000 Dryer - Ele
Admiral LA2000A Dryer - Ele
Admiral LA2000H Dryer - Ele
Maytag LA200S Washer - Top Loading
Maytag LA202 Washer - Top Loading
Maytag LA202S Washer - Top Loading
Maytag LA203 Washer - Top Loading
Maytag LA203S Washer - Top Loading
Maytag LA206 Washer - Top Loading
Maytag LA206S Washer - Top Loading
Maytag LA207 Washer - Top Loading
Maytag LA208 Washer - Top Loading
Maytag LA209 Washer - Top Loading
Maytag LA209S Washer - Top Loading
Maytag LA210 Washer - Top Loading
Maytag LA210S Washer - Top Loading
Maytag LA211 Washer - Top Loading
Maytag LA211S Washer - Top Loading
Maytag LA211T Washer - Top Loading
Maytag LA212 Washer - Top Loading
Maytag LA212S Washer - Top Loading
Maytag LA212T Washer - Top Loading
Amana LA22391.A Mwave - Family Size (60 Hz)
Amana LA23400.A Mwave - Family Size (60 Hz)
Amana LA23400.B Mwave - Family Size (60 Hz)
Amana LA23500.A Mwave - Family Size (60 Hz)
Amana LA23500.B Mwave - Family Size (60 Hz)
Amana LA23600.A Mwave - Family Size (60 Hz)
Amana LA23600.B Mwave - Family Size (60 Hz)
Amana LA23700.A Mwave - Family Size (60 Hz)
Amana LA23700.B Mwave - Family Size (60 Hz)
Maytag LA23CS Washer - Top Loading
Amana LA25700.A Mwave - Family Size (60 Hz)
Amana LA25700.B Mwave - Family Size (60 Hz)
Amana LA25800.A Mwave - Family Size (60 Hz)
Amana LA25800.B Mwave - Family Size (60 Hz)
Maytag LA25CM Washer - Top Loading
Maytag LA25CME Washer - Top Loading
Maytag LA25CS Washer - Top Loading
Maytag LA25CT Washer - Top Loading
Maytag LA26CD Washer - Top Loading
Maytag LA26CDC Washer - Top Loading
Frigidaire LA271EXW1 Wwh(v1) / Top Loading Agitator Washer
Frigidaire LA271EXW2 Wwh(v2) / Top Loading Agitator Washer
Frigidaire LA271JXW3 Wwh(v0) / Top Loading Washer
Frigidaire LA271JXW4 Wwh(v1) / Top Load Washer
Frigidaire LA271LXW1 Wwh(v1) / Top Load Washer
Frigidaire LA271MXD1 Wwh(v4) / 27 " Washer
Frigidaire LA271MXD2 Wwh(v4) / 27 " Washer
Frigidaire LA271MXW1 Wwh(v3) / 27 " Washer
Frigidaire LA271MXW2 Wwh(v3) / 27 " Washer
Frigidaire LA271MXW3 Wwh(v1) / 27 " Washer
Frigidaire LA271MXW4 Wwh(v1) / 27 " Washer
Frigidaire LA272AXW1 Wwh(v1) / 27 " Washer
Maytag LA282 Washer - Top Loading
Maytag LA282T Washer - Top Loading
Maytag LA283 Washer - Top Loading
Maytag LA283T Washer - Top Loading
Maytag LA284 Washer - Top Loading
Whirlpool LA3000XKW0
Frigidaire LA300AXD1 Wwh(v6) / 27 " Washer
Frigidaire LA300AXD2 Wwh(v6) / 27 " Washer
Frigidaire LA300AXW1 Wwh(v5) / 27 " Washer
Frigidaire LA300AXW2 Wwh(v5) / 27 " Washer
Frigidaire LA300MXD1 Wwh(v2) / 27 " Washer
Frigidaire LA300MXD2 Wwh(v2) / 27 " Washer
Frigidaire LA300MXW1 Wwh(v1) / 27 " Washer
Frigidaire LA300MXW2 Wwh(v1) / 27 " Washer
Maytag LA302 Washer - Top Loading
Maytag LA305 Washer - Top Loading
Maytag LA308 Washer - Top Loading
Maytag LA308S Washer - Top Loading
Maytag LA310 Washer - Top Loading
Maytag LA310S Washer - Top Loading
Maytag LA312 Washer - Top Loading
Maytag LA312S Washer - Top Loading
Maytag LA312T Washer - Top Loading
Whirlpool LA3300XPW0
  #2 (permalink)
Old 04-24-2009, 02:36 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Well, it sounds very much like your lid switch has failed, which if it has is a good thing because it is a cheap and easy repair.
To determine this you need to unplug themachine, remove the two screws holding your console to the cabinet (they may be behind trim pieces which can snap off) and then flip the console up and back.
This will expose a plastic electrical connector going into the cabinet. Disconnect this and use a jumper wire to connect the two outer terminals on the connector coming from the console. Then replug your machine, move the dial to the spin position and engage. If the machine spins the lid switch is your problem.
Any problems, search 'lid switch' on this forum and there are loads of discussions and instructions.
The part is
Replacement parts for WHIRLPOOL LSQ9544KQ0 | AppliancePartsPros.com
and you can search elsewhere on this forum for instructions of how to take the cabinet off and replace it.
Good luck and let us know what happens.
__________________
  #3 (permalink)
Old 04-24-2009, 06:38 PM
Junior Member
Default
Thank you so very much! You were so right.. My Lid switch snapped off the plastic part. So I actualy which was probably stupid on my part held it down manualy to drain the machine. I did go and purchase a new machine for the mear reason it is 9 years old and from what i was told they last anywheres from 10 to 12 years,, I appreciate this site so much.. I will be back.. Thank you again
  #4 (permalink)
Old 04-24-2009, 06:50 PM
Senior Expert
APP Volunteer
Default
Thanks for the update, hope your new machine works well and that you don't have to come back!
__________________
  #5 (permalink)
Old 04-24-2009, 07:52 PM
Junior Member
Default
Thank you so much me either but I have added this site to my favorites and will tell my froends about it.. Have a great week end..
  #6 (permalink)
Old Yesterday, 09:28 AM
chisselgw2 chisselgw2 is offline
Junior Member
chisselgw2 is on a distinguished road
Default
Ive Got Same Problem. Its Your Coupling On The Motor Where It
Connects To Gear Box. I Was Hoping To Find Out How To Install
It On This Site. No Luck Yet. Cant See To Good Anymore.
Good Luck With Yours. Chisselgw2
  #7 (permalink)
Old Yesterday, 02:53 PM
Senior Expert
APP Volunteer
Default
This video will show you how to replace your coupling
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
my washer doesn't spin or drain monickm Washer Repair 1 04-07-2009 04:11 PM
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 08:44 AM
washer won't drain or spin malarkeylady Washer Repair 1 08-02-2008 11:46 AM
Washer won't Spin and drain jvejrp1 Washer Repair 0 07-14-2008 02:38 PM
Washer will not drain or spin fenderi Washer Repair 3 01-19-2008 10:17 AM
