Discuss
pump out but no spin
 in
Washer Repair
My 4 year old direct drive Whirlpool Ultimate Care II Washer (no model # to be found anywhere on the machine)
Appliance Repair Forum > Appliance Repair Help > Washer Repair » pump out but no spin
  #1 (permalink)
Old 12-04-2007, 08:17 PM
ericand ericand is offline
Junior Member
ericand is on a distinguished road
Default pump out but no spin
Model Number: Whirlpool Ultimate Care II Washer   Brand: Whirlpool   Age: 1 - 5 years
My 4 year old direct drive Whirlpool Ultimate Care II Washer (no model # to be found anywhere on the machine) is ocsillating during the spin cycle. All other cycles are correct. I have pumpout , so motor is turning. I visually inspected coupler. The drum just jerks about 2 inches back and forth about once a second. I also hear the brakes shrieking during this occsillation. I have replaced the plastic cam actuator and clutch. Thanks in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-04-2007, 10:56 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the drive block.
I can not refer to the break down diagram without the model number. You can find it under the lid.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-05-2007, 03:20 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Sounds like a tranny going sour. Pull it out,turn coupler clockwise, clutch disk should turn, then turn coupler counterclockwise, agitator spindle should oscillate back and forth, please post results.
If ok, check the brake shoes for operation/release, just turn plastic cam clockwise and look for brake release.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag will not spin agitate or pump drembo Washer Repair 7 12-25-2007 03:37 AM
LG pump may be bad or have something stuck Jamiepe Washer Repair 2 10-24-2007 11:16 AM
Pump Drains Tub But No Spin Cycle matt b Washer Repair 2 09-26-2007 05:51 AM
Washer won't drain during spin cycle. Water Pump Belt discovered on floor sandydjdm Washer Repair 1 08-14-2007 08:41 PM
Changing Pump pdiddy Washer Repair 1 07-20-2007 07:05 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
